Mark,
Thought your inverter/charger was Victron Multigrid 48V/3000 + Venus GX,
SIMPbms will show as SIMPbms/battery in screen of Venus os, and will control Victron.
Victron has a wide voltage span you adjust in Victron firmware using a MKII usb to VE converter, Victron can adjust to a max of 66V charging end voltage, this is matching a 16S LEV50 (=maxV 65.6)
In any case a full pack 88cells as in i-MIEVdonor packs has 10x 8S cellblocks with cmu addressing 8 cells + 2x 4S blocks with cmu addressing 4 cells
so you have always, whatever set-up, whatever bms you use,some hot-spares.
My suggested set-up with SIMPbms + i-MIEV pack will be to go for 5 parallel strings of 16S cells,
all cellsfrom same donor pack, so residual Cac should be in balance.
SIMPbms is plugplay with Victron kit.can-bus out 500kbps to Victron can in, terminated with resistor on both ends
on wish list for development of SIMPbms is a master, slave version, so one can add more drive packs to a ~48V'ish system, upgrading capacity of storage battery bank.
SIMPbms has no graphical interface, like other BMS system, check Batrium, just great, and others,
SIMPbms has only a serial comand line with a tree-structure, but in combo with Venus os, one has still all features, like VRM portal,remote control on Venus GX/Multigrid, online switch off, even using key relays to shutdown batterypack main contactor.
see:
https://www.diyelectriccar.com/forums/showthread.php/fs-tesla-vw-outlander-bms-master-198263.html
https://github.com/tomdebree
I team up with Daniel Boekel, together "the europeancontinental support unit", pm me if you like to give SIMPbms a try,
I have sets of boards here in my workshop.
best Carel
View attachment 8376View attachment 10883
last photo is test-rig with 5 parallel strings of 15S LEV40 to match voltage span of max 63Vdc of SMA Sunny Island 8.0, currently undergoing testing in workshop
canbus loop made out of recycled JST cpd connectors hooked up to 10cmu's, last 16'th cell is mock dummy, made out of wood,
SIMPbms has an "ignore mode" to dump failing cell, in this case number 8cell of second LEV40-8 block in the string
If used on a Victron I could have used all cells of an Outlander pack
