Home PowerDrive V2 - Germany ** 50+ kWh ** Big Power ++
Walde
Hello everybody
My new project - Home PowerDrive V2 - Germany
EASUN POWER 5000W Solar Inverter 80A MPPT Off Grid Inverter 48V 220V Hybrid Inverter Pure Sine Wave Inverter 60A Battery Charger
(not mounted yet)
+ Solar Power 6095Wp (23x265Wp - Astronergy PENTA 5BB 265Wp poly -ASM6610P Serie - Made in Germany) (not mounted yet)
+ LI 18650 Second Life Storage (not mounted yet)
to test batteries
6x Opus BT-C3100 v2.2
3x imax B6
20x TP4056 mini Charger + (40x TP4056 mini Charger not mounted yet)
New:
Fuses to test with the 18650 via Aliexpress now arrived: 2000x 0,5A, 2000x 1,0A , 2000x 2,0A Axial Fast Glass Fuse With Lead Wire 3*10
https://de.aliexpress.com/item/1000...lead-wire-3-10-2A-registered/32739650661.html
To repair defective cases on the 18650 2x 10 Meter via Aliexpress now arrived : CNIM Hot 10M 29.5mm PVC Heat Shrink Tubing Wrap for 1 x 18650 Battery Light Green
https://de.aliexpress.com/item/CNIM...108.1000016.1.3bb47ff4VRzcGY&isOrigTitle=true
The first 100 pieces 4x5 Cell 18650 Batteries Spacer Holders via Aliexpress now arrived : https://de.aliexpress.com/item/Neue...lter-Strahl-Shell-Kunststoff/32842406477.html
*** I hope it is ok to set the link here. Otherwise please short info and I'll take him out. ***
Follow pictures
PS: I would be glad about German contacts to Kollgen in Germany
I'm testing
Bin am Testen
:s
Welcome and keep on building!
Herzlich willkommen und viel Spa beim Basteln :) . Und bei Fragen einfach fragen :D
Have sun!
Oliver
Now I have something to do again on the weekend.
Get 68 kg of used batteries today.
I guess about 1000-1200 cells 18650 times when it runs well.
Wishing you a nice weekend
Jetzt habe ich wieder was zu tun am wochenende.
68 kg gebrauchte Akkus heute neu bekommen.
Ich Schze mal ca. 1000-1200 Zellen 18650 wenn es gut luft.
Ich wnsche ein schnes wochenende
Walde said:
Today 10 new E-Bike Akkus = 400 LiPO 18650
all Lipo 2900 to 3400
I think its lithium mangane what youve gotand no lipo...
Hey Walde,
I've also started with my Powerwall this year.
I see you got some e-bike batteries.
I also got some - Brand Fisher - like the left on on your picture.
Question: how do you get the cells out of the cage, as mine are not easy to dissassemble.
Additionlay, mine are flooded with some black rubberliquid, big mess to get rid of.
ATM I have to use mechanical force to get the cells out, but they loose their insulation with this methode.
regards
cadric
Hi Walde
ich hab in diesem Jahr auch mit dem Bau einer Powerwall begonnen.
Ich hab auch einige e-bike Akkus, gleiche wie der Linke auf deinem Foto, Marke Fischer.
Frage: wie bekommst du die Zellen aus ihrem Kfig, ohne sie zu zerstren? Meine lassen sich nicht zerlegen.
Zustzlich sind meine auch noch mit einer schwarzen, gummiartigen Flssigkeit eingegossen, ziemiche Sauerei, die zu entfernen.
Zur Zeit entferne ich die HalterPol fr Pol mit einen Holzmeiel, um dann die Zellen, die Parallel geschaltet sind separat herauszutreiben.
Dabei verlieren sie natrlich ihre Isolierung.
Gru
cadric
cadric said:
Hey Walde,
regards
cadric
Hi Walde
Gru
cadric
Plastik Werkzeug und eine Kombizange und einen Seitenschneider + Lederhandschuhe / Schweierhandschuhe
Plastic tool and a combination pliers and a side cutter + leather gloves / welder gloves
MfG Dirk
Walde said:
cadric said:
Hey Walde,
regards
cadric
Hi Walde
Gru
cadric
MfG Dirk
Hi Dirk,
thanks for your reply, but I was more interested, If you have a speciall solution to open the cages.
But I will ask in a seperate thread, for ideas. Thanks.
cadric
mining rig second housing conversion
-> 18650 Cell Mining Rig <-
I have to install the second and third loader then it should be 3x20 load units in the Mining Rig total for 60 cells 18650
