Home PowerDrive V2 - Germany ** 50+ kWh ** Big Power ++
Walde
Problem defective Sahara sand? No!
It's time to clean the solar system,
last week we had desert fine dust in the rain and the solar system looks accordingly
.... CLEANING is the order of the day.
Walde
.... CLEANING DAY !!!
Speed CLEANING 10min
CLEANING Complete 1hr
@Walde Need to check your videos. They aren't accessible. Are the links correct?
Just post the youtube link. No need to put them inside the youtube tags.
Walde
Thanks. I'll check and correct that right away.
Update: Links Work
Have you considered tilting the panels by slightly raising one side of each panel? Raising just 1cm on a 1m wide panel creates a 1% slope - a typical amount for a drainage pipe. I imagine that'll reduce dirt accumulation significantly, except for the lips on the very edge of the panels.
Walde
Yes, we always have in Germany.
The default in Germany is According to the Flat Roof Directive, a flat roof should have a minimum slope of 2%. This corresponds to a roof pitch of 1.1 degrees. This will ensure proper drainage of the roof.
Walde
Solar system control with emergency power.
UPS with AGM battery system.
What happens to your system control in the event of a power failure?
