rebelrider.mike
- May 25, 2017
- 554
The Misc. circuit has an interesting story. And by interesting, I mean long and boring. When we first moved in, the Misc. circuit was a collection of branches that seemed to feed about half the house. The whole upstairs minus the bathroom, but including a 120V Cadet heater. All the lighting on the main floor, the bathroom receptacle, and the two receptacles in the kitchen. Needless to say, it tripped a lot.
We had the refrigerator in the dining room, and pretty much couldn't use the kitchen or bathroom outlets for quite a while. I found that pretty much all the wiring was made of the old insulated knob and tube stuff. Some of which was in perfect condition, some of which was deteriorating from obvious overheating. When I remodeled the kitchen in 2016, I found hidden junctions in the wall without boxes, and mostly held together with wire tape. It all got upgraded, and the kitchen has 5 new circuits that are up to code. The range and the dishwasher already had their own circuits.
I've also been upgrading other parts of that Misc. circuit, to take more load off of it. I've since found more junctions in the attic with no boxes or wire nuts. Some wires are simply wrapped around exposed sections of other wires and covered with tape. The goal is to eventually make the whole circuit go away.
In other news, I decided to get myself an NEC 2020 code book. Now if only I had the decoder ring too... Well I may not be able to interpret it, but I'll at least be able to reference it when asking questions. Washington only adopts every other code update, so It should be good for another 3 years I think.
I've collected enough information now to know what circuits I want on the solar sub panel. Some of the circuits aren't finished yet, and some don't exist yet, so I've been planning things out a bit. I've been thinking about how circuits on sub panels are supposed to be "paired" so that the sub panel can be as balanced as possible. It's caused me to rethink the positions of all the circuits I have everywhere. I've color coded each circuit position on each panel so that I can easily see which positions would be paired so that one space is on bus A while the other space is on bus B. I hope that make sense.
2 Pole breakers are self balancing of course, but an example of a good pair would be the fridge and freezer. Both run often and take kind of vaguely the same amount of power. And with all these circuits on the sub panel, the main panel is freed up for future stuff.
I've also used colors to show which circuits need what. White are ones I'm still not sure about. Blue are ones I'm sure of, but haven't started yet. Yellow are in progress, and green are finished. I don't know when I'll be getting a heat pump or replacing the conventional water heater with a heat pump water heater. So for now, those are just sort of place holders.
Just for fun, here are the other two sub panels I'm working on:
The second floor sub panel is for all the wiring I'm replacing in the attic. When I moved in, the carport had an old Zinsco breaker panel feeding an outlet and a big ol' yard light. I'm sure that panel wasn't rated for outdoors, and it was pretty corroded. I took it out, but I need to replace it with a proper outdoor load center. I'd also like to expand the outdoor lighting and receptacles, so I'd like them to be on two separate circuits.
I'm down to choosing between a 16 space panel and a 20 space panel for the solar sub panel. 20 would give me spaces for future circuits, but I'm limited to 40A total, and I don't want to overload it. The main panel will have plenty of space for new circuits, just not powered by solar. The main and solar sub panels will be within inches of each other, so it physically wouldn't matter which panel I used for new circuits. 16 would save space, but then I'd be limited. The cost is about the same. I don't know.
