jesusangel said:
I think the best way is you or your electrician do some cabling and install some automatic or manual transfer switch so you can select the input for you whole house from grid or from your inverter or with more work you can set individually for every circuit so you can have oven and high power appliances connected to grid and light or low power appliances to the inverter.
That would be the most effective way to go. You would probably opt to keep the heavy draw appliances off the inverter. Heating uses a lot of power, so unless you have a really large system, its best to leave those on the grid.
By having a transfer switch you can use your existing cables and power points. Most houses even have more than one circuit.
You may even want to look at a solution like the Victron Multi Grid. It basically does not back feed the grid, but rater forward grid power when the inverter can't keep up, or the battery goes flat.
