Hi! Yes to moment i have think it was easy, but on 3 Bicycles battery, 2 model, i have should use dremel to open and access on full lithium Cell.
To now, i have left 1 model, i have think first, this left i would reuse it later, but the model don't change on other, the enclosure type is same!
this all use same model for lithium cell. But so you can see it, the enclosure is complete close, so i think, to open it and to dismount the complete batterie, i should use new time dremel tool, because is aluminium, and the batterie holder should are glue into 3 positions, Start, medium and End on Disclosure.
Or have you different view to dismount all cell integrated into this case? 36V 15Amp battery.
I don't have success to Push it out, (glue is to heavy). I have try to push into all two way. nothing result. and this cell holder, don't have hole to give possibility to pass a thread, and after to pull it out from case.
so thanks to all idea which can me help.
