How to fix 18650 packs on the wall ?
Bib60
Hi
I would like to fix 30 packs 13S10P on the wall.
Do you have a idea for it ?
Take a look at my packs
Maybe you should give more details. What's there to fix? They look fine to me. Unless you want to make a different arrangement, like 14s9p (10p would require 10 more cells added), or to something else.
Bib60
Hi
Yes you are right Offgridinthecity.
You can see on picture 3 packs, i have 30 packs like this.
I would like to fix all my 30 packs to my wall, what is the best way ?
Can i find support who had made for 18650 ?
Or must i build myself with wood or metalic ?
The packs you can see are 13S10P
Thanks a lot
Laurent
Pretty much build your own. HBPowerwalls has the stl for his type of holder you could use, modify for pack size, and have a machinist make it for you.
You could also use large shelf brackets, the utility kind being flat L shaped bars, to hold them too.
Or you could just have them lay on a shelf, or a drawer.
Really, there are many ways to mount these. Just depends on your needs, space available, skill level, budget, etc
In my case, I have a cinder-block wall under the house where I mounted adjustable shelf rails nd have my packs sitting on shelves. However this isn't as fireproof as the current recommendations.
There are several threads on fireproof plans - here's a recent one - https://secondlifestorage.com/index.php?threads/fire-proof-containment.10202/ Later in this thread you'll see some custom boxes and metal cabinets :)
