- Jan 7, 2017
- 8,100
Someone on the FB bought... 360Ah cels (360 !!!!)
It has OCP errors...
360Ah isn't impossible, they are available. Altho it is odd to get them second hand already as they are relatively new to the market.
Just because the QR code isn't readable doesn't make them fake, just means they aren't in the database. It does make them suspect, though.
Not sure what the 2nd picture is conveying here, are the plastic caps incorrectly placed?? You haven't really provided much information about these cells.
Also, what are the dimensions of the cells? The thickness to be >320Ah is most likely going to be about 84mm. If these are 72mm, then they are in fact not 360Ah cells, unless they are taller than standard, which is 207mm.
Now, it is possible if the labeling is incorrect, then that might be why they are on the market, and would also explain the QR not being listed. As they would technically be "defective" from a manufacturing process, and instead of throwing them out, they just sell them as B or C grade cells and still make a little money off of them.
