How to test 26650's on an imax B6
harrisonpatm
On my last batteryhookup order I got a pack of A123 26650 LFP cells from medical laser treatment, or whatever. Just for fun really, I mostly process and test laptop 18650s, but LFP is good for some outdoor applications, thought they would be handy to have around.
Since all my equipment is setup for 18650s and Li-Ion, how can I discharge test these? I have an Imax B6 tester that has settings for LFP, but I don't have a good way to secure leads to the cell. Can someone recommend a method to discharge test these for checking capacity?
If I need to purchase a different charger, tester or piece of equipment, I'm just going to skip it, I don't plan of processing this size of cell or chemistry on a regular basis.
OPUS has a slider switch inside you can set for LifePo4 and then use the charge/discharge cycles as you would for 18650 lithium-ion.
Maybe 2 of them would fit? Or, extend the normal contacts with a wire/magnets hack?
harrisonpatm
Nice! I have 1 opus. Looks like 2 of them will fit. Thanks for the tip
Cool. Here's the hidden switch
From one of our favorite youtube personalities :)
View: https://youtu.be/GDUikK7jQoo
Jeb5573ptm
I wonder why this feature isn't advertised, or why the switch is hidden/not easily accessible.
My guess would be the limited understanding of the difference between 3.7v LiPo and 3.2v LifePo4 cells.
I can see the headlines now "It fit in my charger and then my house burnt down!!! Switch, what switch? Oh, I forgot to switch it back..."
