I have a confession to make.. I have been working on a diy BMS for a while now...
Duchess
And haven't told you guys yet.
I think its pretty neat.
I had been looking for a custom BMS or even anything that fit my particular “wants” and could not find anything interesting online I decided to just make my own from pretty much nothing. Cool huh?
And it works!!! I am still in prototype but I am soooo close to getting it completely done hardware wise and need some help with the software stuff.
Want to Play a game?
fake edit: Also- I have never done anything like this ever...
More details are always welcome ;)
Looks pretty good so far. I'm assuming you are using opto-isolaters between packs to keep from shorting? If not, how are you getting around the command ground issue?
FarmerJ
I can write software code. I've been trying to learn electronics and circuit components/design and keep managing to make lots of white smoke, but I might finally comprehend Ohms Law and how to test individual components with my multi-meter.
You are writing "Current" in grafana but you are presenting Voltage ;)
Also it looks like you dont have any external fets for balancing but only using the built in balancing. Is that correct? Because it can only max do 50mA internally.
With that said those chipsets including its larger brother 76940 are nice small ones and are embeded in many systems :) There are also versions on github with the popular ESP chipsets so you get wifi/bluetooth function :)
Good work
ng.sa
G'Day Duchess
[NG] I wish I had the skills to do the hardware like this, good job !!!
[NG] How have you generated this, is this using custom software ???
I cannot see the interface between the SD Card ( looks like 32GB in the 3rd pic. ) on the board, are you thinking about writing output from the BMS to the SD Card ?
Are you going to build a PC app. ?
If your write your code in the language C you can blow a ROM from your code and eventually create a full hardware BMS.
Duchess
Current - as in passing of time
What I posted is not a Battery Management System. I have a different prototype for that. I have a few other versions with power fets and whatnot.
Custom Arduino code. Node red. influxDB. Grafana... ETM
Sorry, SD card for scale. not needed for this Battery Monitoring System.
The data streaming into Grafana is real time.
right now it goes from the TI afe to an Arduino Uno via i2c to a raspberry pi running node red, influxDB and Grafana over serial. I am planning to make a plugin for node red just for the TI afe hopefully at some point eliminating additional hardware and programming.
oh btw not only do I have different versions with additional functionality there is more of a eco-system. If you notice in the Grafana snapshot it shows "Pack 1"...
it hot swaps too. I have the BMS disconnected right now on pack 2. The noisy readings on the other packs are resolved with a new hardware revision (testing on pack 1
I need help with the Arduino code and hopefully something for node red.
I saw that and I see that code all over the internet in different shapes and forms.
I cant believe nobody has asked me for what battery topology/configuration yet lol it says it on the board if you can figure it out.
peace out.
-Duchess​
Those of us who are familiar with this chip, it kinda narrows down what it's for ;) And yeah, i saw the screen stamps showing it's uses. I like the Bender peeking out too :cool:
Yes if you are using Grafana pre version 8.0 and the "Old" Graph Panel instead of the "New" Time series graph that "Current" legend just means as in what is happening now. The new time series graph changes that.
