I need the BOSS in excel :D If anyone can help...
WuggyBuggy
Any excel pros in the DIY forum? :)
I have an idea for my excel sheet (Counting cells). But I cant find the right formula on google.
I have 4 rows of cells (A2:D2000 ish).
I max want to count 4800 which I need for my packs (2x 14s200p). I want excel to sort out all the lowest cells first. So my max is always 4800, but when i add more high cells. The lowest cells will be deducted.
Is this possible (I'm sure if it, but not for a noob like me). But how?
BlueSwordM
Plenty easy.
1. Select all of your data.
2. Go into the Data page.
3. Sort by ascending.
You're done :)
WuggyBuggy
w0067814 said:
=(LARGE(cells,ROW(INDIRECT("1:4800"))))
Where "cells" is a huge named range containing all your values.
=(LARGE(2:200;A: D(INDIRECT("1:4800"))))
is this correct? I get a REF! Had to make a space after A: or it will make a smiley. Seems like the 1:4800 is not enough. Hmm
WuggyBuggy
BlueSwordM said:
Plenty easy.
You're done :)
Allready did that ::) But to boring :D
w0067814
Yes, my original formula is correct, which is amazing as I did it on my phone. Too many brackets though.
It returns an array of values from a named range of cells called "cells". Attached is an example of how you can use it.
Hope this helps.
  • Excel_Cell_Sizes_Example.xlsx
WuggyBuggy
Wow this is great woo! Thanks a bunch. I'll sit and take a good look at it!
Thanks again!
