100kwh-hunter
- Mar 2, 2019
- 665
After 2 years of studying and experimenting i think i found MY golden match....I think, that is.
I would really appreciate your opinion, thoughts, ideas and comments!!!! and every thing else.
End goal: 9 of the inverters and 90 of those panels.
Use two ev cars, home heating(direct into a water tank, so no cells are in this section of the system) electric cooking light ect.
Home heating:
DERNORD Stainless Steel 48v 1500w Electric Immersion Water Heater DC Heating Element|electric element water heater|element water heaterelement heater - AliExpress
with:
110V 220V 12V 24V Digital Temperature Humidity Controller Thermometer Hygrometer Incubator Dehumidifier Thermostat Humidistat DC|Temperature Instruments| - AliExpress
I orderd this one for my tobacco curing room, they have it also for 48v temp cut of to max 25a(first storage:water well 35C, home heating, second storage:shower bath ect 70C)
Inductive cooking will be implemented!
But this is a different threat(2x)
End goal to get rid of all the roberments connections....
PIP-MGX.pdf (mppsolar.com)
This would be theinverter of my choose...(to build up of course......of course i will start with one and every year i will add one or twomore every year!)
Solar pv pannels:
Shop GWL | Solar panel GWL/Sunny Mono 450Wp 72 cells, PERC (ESM-450 Pack 4 pcs)
I think there are a good match, but the amount of panels according to there wp or total Ah deliver gives me some confusion?
Really need some clearance on this and how much panels can i connect to one inverter?????
Please answer this one: hoe much pv i can connect IF they are a match?
Probably not 10 pv panels at each inverter i would like to give them a easy live.
But two times a string of9 inverter string? if this is possible?
Thought and comments on this is also very welcome and appreciated, many many thanks in advance.
The bms is a other subject: 123smart of gwl or batrium? both are stand alone? and both can handle max 255 units(280ah can be one, two 150 = 300 can be one)
Thoughts and advice on this one is also greatly appreciated.
BMS123 Smart Gen3 - Complete Set (4 cells) with Bluetooth 4.0 | shop.GWL.eu
Basically is the inverter and the panels a good match and how much pv can i connect to one inverter, this i still something dont get, yet.....
Thoughts on the bms???
With best regards Igor K, and thanks in advance
https://shop.gwl.eu/Electric-Cars/?cur=1
Will also a different threat!
Best...
PS i am NO vendor or get money of commercial displaying links....
Home heating:
with:
Solar pv pannels:
Best...
