Dr. Dickie
- Sep 23, 2020
- 122
So I picked up a ABB SACE S5 circuit breaker with the 24V shunt trip that I plan to wire into my system. I have watched LithiumSolar's vids on his set-up.; and I have a question kind of related to that. He switched (with the center post on the breaker) the feed to his inverter so that if the system tripped, the PV array could not continue to feed the inverter. Makes sense.
However, every solar charge controller that I have had (I have a new Midnight controller coming, don't have it yet) wanted the battery to be connect to the controller first then the PV input. This make sense to me as the controller gets its power from the battery and you would want it powered up before hooking up the array input. IF the battery SOC gets too high or too low and the shunt trip flips the breaker, it shuts off battery power to both the inverter and the charge controller. However, the PV array would still be putting current into the solar charge controller--from what I understand that might be bad for the controller. I plan to wire the negative from the PV array through the center post of the breaker so that the inverter, the controller, and the PV array input, all get shut off in the event of a too high or too low SOC event (or critical fault from Batrium BMS) happens. Would there be any thing wrong or problematic about doing it this way?
