- Feb 25, 2020
- 849
After 1 year or so I've got the first battery 14s20p prepared (prepared, not finished yet!). Very long job, last year I made the cell selection and had panels and inverter ready.
Cell buckets after 1yr
Cell are divided in buckets, from 2000 to 2300mAh (buckets: 2000-2099, 2100-2199, 2200-2299) and grouped by IR, from 20 to 60 (buckets: 20-39, 40-49, 50-59, 60-69).
Found quite interesting measurements on the cells kept in storage for 1 year. Most cells were in the 4.12-4.13V range. A few were just under 4.10V. A couple, discarded them, were under 4.00V. IR has raised in most cases of 5-8mOhm, on some cells it raised of 10-15mOhm. On a few it raised 20mOhm.
Incredible to find a bunch of cells still at 4.20V, wow.
Here's some photos... each of the 14 modules is around 42Ah at nominal 3.7V.
Cell were picked using a round robin strategy, this was quite interesting to do, because the series connection isn't symmetrical (the busbars connect each module on the top side, not in the middle). So I have different busbars for + and - modules.
Notes on cells
I avoided using Sony green cells of the GR series because of the many problems documented here in the forum. And all cells I used are ICR.
Notes on module making
Charged all cells before making the modules to have similar voltages in all cells.
Spot welding test OK
This point scared me a bit after a negative experience with a 10$ cheap device (only good for some random nickel strip welding, nothing else). I did a better test with my Sunkko 709AD, oh... I love it!
Spot welding fuse wires can be very time-consuming, but after getting the hand (and the foot, too, using the pedal) with it I was quite fast. I think soldering is faster but I'm sure now I can go with spot welding. I set the device at current=2.5 and pulse=4 to get a solid spot on the 35SWG 0.2mm nickel plated copper wire. I don't know how many spots I can weld with the copper tips... I have two spare sets, should be enough for now.
Here's a photo of my first test yesterday (using dead cells)... The welder doesn't like irregular surfaces...
Testing module capacity
This was a difficult choice. I don't have anything to test each module's capacity. I could use a bunch of 5W resistors... yes. So I spent two days making a circuit to have a constant load using a transistor, an op-amp and the resistors. What I didn't realize is that this circuit will keep a constant load when testing a PSU but not testing a battery. I managed to get a 5.5A load, which goes down to 4.2A when batteries reach 2.75V.
I'm using a circuit found on ElectroNoobs.com and modified it just a bit for my needs, here's some photos...
... so I'm ready to spot weld these first 280 cells, bought extra 175mt of fuse wire just to be on the safe side, found a good price on Ebay, 10€ for the wire (!), 7€ taxes for buying from the UK and 12€ for shipping, very good!
It will still take me quite a bit of time to get everything up and running, meanwhile I did my experiments welding metal bars to make a solid structure to hold solar panels up on my balcony (that's another journey... oh my! didn't expect it to be so difficult! LOL).
Notes on cells
