I am also asking for info on how to run jk-b2a24s in grafan: P
thanks greetings.
Query BMS via BLE
Reading config file: /etc/jkbms/jkbms.conf
Logging level: 20
jkBMS Logging level: 20
Delegate JKBMS instance --- name: Power Wall 1, model: JK-DZ11-B2A24S, mac: 3C:A5:19:7B:27
0, command: command, tag: Power_Wall_1, format: influx2, records: 1, maxConnectionAttempts: 3, mqttBroker: None
INFO:JKBMS-BT:Attempting to connect to Power Wall 1
INFO:JKBMS-BT:Connected to b'JK-DZ11-B2A24S\x00'
INFO:JKBMS-BT:Read characteristic: Characteristic <ffe3>, handle 10
INFO:JKBMS-BT:Enable 0x0b handle
INFO:JKBMS-BT:Enable read handle
INFO:JKBMS-BT:Write getInfo to read handle
INFO:JKBMS-BT
rocessing info record
INFO:JKBMS-BT:Record number: 153
INFO:JKBMS-BT:VendorID: JK-DZ11-B2A24S
{'VendorID': 'JK-DZ11-B2A24S'}:influx2:None
ower_Wall_1
INFO:JKBMS-BT
evice Name: JK-DZ11-B2A24S
{'DeviceName': 'JK-DZ11-B2A24S'}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Hardware Version: 3.0
{'HardwareVersion': '3.0'}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Software Version: 3.3.0
{'SoftwareVersion': '3.3.0'}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Uptime: 0D23H0M0S
{'Uptime': '0D23H0M0S'}:influx2:None
ower_Wall_1
INFO:JKBMS-BT
ower Up Times: 4
{'Power Up Times: 4'}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:notificationData has ACK
INFO:JKBMS-BT:Write getCellInfo to read handle
INFO:JKBMS-BT:Grabbing 1 records (after inital response)
INFO:JKBMS-BT
rocessing extended record
INFO:JKBMS-BT
rocessing cell data record
INFO:JKBMS-BT:Record length 300
INFO:JKBMS-BT:After position 3: 2
INFO:JKBMS-BT:After position 2: 3.359375
INFO:JKBMS-BT:After position 1: 3.3717041015625
INFO:JKBMS-BT:After position 0: 3.3717079162597656
INFO:JKBMS-BT:Cell: 01, Volts: 3.3717
{'VoltageCell01': 3.3717079162597656}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 3.37451171875
INFO:JKBMS-BT:After position 0: 3.3745412826538086
INFO:JKBMS-BT:Cell: 02, Volts: 3.3745
{'VoltageCell02': 3.3745412826538086}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 3.37310791015625
INFO:JKBMS-BT:After position 0: 3.373124599456787
INFO:JKBMS-BT:Cell: 03, Volts: 3.3731
{'VoltageCell03': 3.373124599456787}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 3.375
INFO:JKBMS-BT:After position 1: 3.3773193359375
INFO:JKBMS-BT:After position 0: 3.3773746490478516
INFO:JKBMS-BT:Cell: 04, Volts: 3.3774
{'VoltageCell04': 3.3773746490478516}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 3.3787841796875
INFO:JKBMS-BT:After position 0: 3.378791332244873
INFO:JKBMS-BT:Cell: 05, Volts: 3.3788
{'VoltageCell05': 3.378791332244873}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 3.38018798828125
INFO:JKBMS-BT:After position 0: 3.3802080154418945
INFO:JKBMS-BT:Cell: 06, Volts: 3.3802
{'VoltageCell06': 3.3802080154418945}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 07, Volts: 3.3774
{'VoltageCell07': 3.3773746490478516}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 08, Volts: 3.3774
{'VoltageCell08': 3.3773746490478516}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 09, Volts: 3.3802
{'VoltageCell09': 3.3802080154418945}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 3.38299560546875
INFO:JKBMS-BT:After position 0: 3.3830413818359375
INFO:JKBMS-BT:Cell: 10, Volts: 3.3830
{'VoltageCell10': 3.3830413818359375}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 11, Volts: 3.3774
{'VoltageCell11': 3.3773746490478516}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 12, Volts: 3.3788
{'VoltageCell12': 3.378791332244873}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 13, Volts: 3.3731
{'VoltageCell13': 3.373124599456787}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 14, Volts: 3.3745
{'VoltageCell14': 3.3745412826538086}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 15, Volts: 3.3774
{'VoltageCell15': 3.3773746490478516}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 16, Volts: 3.3788
{'VoltageCell16': 3.378791332244873}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 17, Volts: 0.0000
{'VoltageCell17': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 18, Volts: 0.0000
{'VoltageCell18': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 19, Volts: 0.0000
{'VoltageCell19': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 20, Volts: 0.0000
{'VoltageCell20': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 21, Volts: 0.0000
{'VoltageCell21': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 22, Volts: 0.0000
{'VoltageCell22': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 23, Volts: 0.0000
{'VoltageCell23': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 24, Volts: 0.0000
{'VoltageCell24': 0.0}:influx2:None
ower_Wall_1
{'VoltageTotal': 54.03374433517456}:influx2:None
ower_Wall_1
INFO:JKBMS-BT
rocessing wire resistances
INFO:JKBMS-BT:After position 3: 0.125
INFO:JKBMS-BT:After position 2: 0.1376953125
INFO:JKBMS-BT:After position 1: 0.13832473754882812
INFO:JKBMS-BT:After position 0: 0.13832587003707886
INFO:JKBMS-BT:Cell: 00, Resistance: 0.1383
{'ResistanceCell00': 0.13832587003707886}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 3: 0.03125
INFO:JKBMS-BT:After position 2: 0.1171875
INFO:JKBMS-BT:After position 1: 0.11728477478027344
INFO:JKBMS-BT:After position 0: 0.11728477478027344
INFO:JKBMS-BT:Cell: 01, Resistance: 0.1173
{'ResistanceCell01': 0.11728477478027344}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.1123046875
INFO:JKBMS-BT:After position 1: 0.11254215240478516
INFO:JKBMS-BT:After position 0: 0.11254262179136276
INFO:JKBMS-BT:Cell: 02, Resistance: 0.1125
{'ResistanceCell02': 0.11254262179136276}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.11767578125
INFO:JKBMS-BT:After position 1: 0.11778545379638672
INFO:JKBMS-BT:After position 0: 0.11778612062335014
INFO:JKBMS-BT:Cell: 03, Resistance: 0.1178
{'ResistanceCell03': 0.11778612062335014}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.11279296875
INFO:JKBMS-BT:After position 1: 0.11290168762207031
INFO:JKBMS-BT:After position 0: 0.11290179565548897
INFO:JKBMS-BT:Cell: 04, Resistance: 0.1129
{'ResistanceCell04': 0.11290179565548897}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.111328125
INFO:JKBMS-BT:After position 1: 0.11148452758789062
INFO:JKBMS-BT:After position 0: 0.1114853210747242
INFO:JKBMS-BT:Cell: 05, Resistance: 0.1115
{'ResistanceCell05': 0.1114853210747242}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.11083984375
INFO:JKBMS-BT:After position 1: 0.11087417602539062
INFO:JKBMS-BT:After position 0: 0.1108749583363533
INFO:JKBMS-BT:Cell: 06, Resistance: 0.1109
{'ResistanceCell06': 0.1108749583363533}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 0.1109476089477539
INFO:JKBMS-BT:After position 0: 0.11094840615987778
INFO:JKBMS-BT:Cell: 07, Resistance: 0.1109
{'ResistanceCell07': 0.11094840615987778}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 0.11102867126464844
INFO:JKBMS-BT:After position 0: 0.11102940887212753
INFO:JKBMS-BT:Cell: 08, Resistance: 0.1110
{'ResistanceCell08': 0.11102940887212753}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.113037109375
INFO:JKBMS-BT:After position 1: 0.11310005187988281
INFO:JKBMS-BT:After position 0: 0.11310017853975296
INFO:JKBMS-BT:Cell: 09, Resistance: 0.1131
{'ResistanceCell09': 0.11310017853975296}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.112548828125
INFO:JKBMS-BT:After position 1: 0.11266040802001953
INFO:JKBMS-BT:After position 0: 0.11266123130917549
INFO:JKBMS-BT:Cell: 10, Resistance: 0.1127
{'ResistanceCell10': 0.11266123130917549}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 0.11324501037597656
INFO:JKBMS-BT:After position 0: 0.11324548721313477
INFO:JKBMS-BT:Cell: 11, Resistance: 0.1132
{'ResistanceCell11': 0.11324548721313477}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 0.11725711822509766
INFO:JKBMS-BT:After position 0: 0.11725746467709541
INFO:JKBMS-BT:Cell: 12, Resistance: 0.1173
{'ResistanceCell12': 0.11725746467709541}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 2: 0.117431640625
INFO:JKBMS-BT:After position 1: 0.11765003204345703
INFO:JKBMS-BT:After position 0: 0.11765042692422867
INFO:JKBMS-BT:Cell: 13, Resistance: 0.1177
{'ResistanceCell13': 0.11765042692422867}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 0.112579345703125
INFO:JKBMS-BT:After position 0: 0.1125798411667347
INFO:JKBMS-BT:Cell: 14, Resistance: 0.1126
{'ResistanceCell14': 0.1125798411667347}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:After position 1: 0.11250972747802734
INFO:JKBMS-BT:After position 0: 0.11250985786318779
INFO:JKBMS-BT:Cell: 15, Resistance: 0.1125
{'ResistanceCell15': 0.11250985786318779}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 16, Resistance: 0.0000
{'ResistanceCell16': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 17, Resistance: 0.0000
{'ResistanceCell17': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 18, Resistance: 0.0000
{'ResistanceCell18': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 19, Resistance: 0.0000
{'ResistanceCell19': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 20, Resistance: 0.0000
{'ResistanceCell20': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 21, Resistance: 0.0000
{'ResistanceCell21': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 22, Resistance: 0.0000
{'ResistanceCell22': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 23, Resistance: 0.0000
{'ResistanceCell23': 0.0}:influx2:None
ower_Wall_1
INFO:JKBMS-BT:Cell: 24, Resistance: 0.0000
{'ResistanceCell24': 0.0}:influx2:None
ower_Wall_1
Got 1 records
INFO:JKBMS-BT
isconnecting...
