Hi all, I am currently using 2 x JK BMS's which work fine on Bluetooth for monitoring purposes, albeit with limited range. Is there an easy way to get both BMS's up on
Wi Fi so that I can see them remotely? Please tell me how to do it. Thanks
ESPHome component to monitor and control a Jikong Battery Management System (JK-BMS) via UART-TTL or BLE - syssi/esphome-jk-bms
github.com
This looks promising. I've looked at it before, just haven't gone through the process of actually hooking up. I think my first bms had a bad com board so it wasn't sending any signals out. I should revisit this considering I have a new bms
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
