Hi,
I have access to truckloads of the Juicy Lion UPS modules used in datacenters. We haven't been able to turn them on properly. Does anyone here have any experience with them? Would be great to just use them as powerwall!
Most likely the BMS have shut down. If possible measure Voltage inside the UPS module before the BMS. How many units are in a truckload?
Just two of the many possiblities the Modules are made to shut down when removed from UPS units, the BMS shut down do to low voltage so was removed. A pic of the modules might lead to a solution. What voltage are they? Chemistry of cells used?
Perhaps make/model of the units would be helpful. There are so many different types of datacenter UPS units it's kinda hard to take a shot in the dark at guessing.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
