LG LGDAHA11865 Cell Specifications
TheBatteries
Administrator
Brand:LG
Model:LGDAHA11865 (ICR18650HA1)
Capacity:1300mAh Rated
Voltage:3.68V Nominal
Charging:4.20V Maximum
650mA Standard
4000mA Maximum
Discharging:2.50V Cutoff
260mA Standard
15000mA Maximum
Description:Green (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://akkuplus.de/mediafiles/Datenblatt/LG/LGDAHA11865.pdf
Pictures:
I found some of these in a Ryobi P102 18 volt battery for power tools. This particular battery is constructed as 5 cells serially connected to the Ryobi battery control board.
Capacity was listed on the battery case as 24 Wh which calculates / 5 / 3.6 as 1304 mAh
