LG LGDAS41865 Cell Specifications
TheBatteries
Brand:LG
Model:LGDAS41865
Capacity:2200mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
750mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
--- mA Standard
--- mA Maximum
Description:Purple (Dark) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
LGDAS41865, ICR18650S4
LG S4 SPECIFICATIONS TABLE
BASIC
Brand LG
Model name(s) ICR18650S4
Manufacturer full LG 화학 (LG Chemical)
Country of Manufacture South Korea
UL number MH19896
SIZE
Weight 47.00 g
Diameter, max. 18.29 mm
Height, max. 65.00 mm
VOLTAGE
Voltage, charge max. 4.20 V
Voltage, nominal 3.75 V
Voltage, discharge end 3.00 V
CAPACITY Capacity, max. 2200.00 mAh
CURRENT
Constant charge current, max. 2.15 A
Charge constant standard 1.05 A
Discharge standard 420 mA
Max. continuous discharge current 4.20 A
Peak discharge theoretic, 4 sec 7.35 A
C-rate (charge, max.) 0.98 C
C-rate (discharge, max.) 1.91 C
POWER Watts (charge, max.) 8.0625 W
Watts (discharge, max.) 15.75 W
ENERGY
Energy, max. 8.25 Wh
Density volumetric theoretic 483 Wh/L
Density gravimetric theoretic 176.00 Wh/kg
E-rate (charge, max.) 0.98 E
E-rate (discharge, max.) 1.91 E
CHEMISTRY
Chemical abbreviation NMC
Cathode LiNiMnCoO2
Anode carbon
TEMPERATURE
Storage (less than 1 month) -20 – 60 °C
Storage (less than 3 month) -20 – 45 °C
Storage (less than 1 year) -20 – 20 °C
Temp charge, min 0.00 °C
Temp charge, max 45.00 °C
Temp discharge, min -20.00 °C
Temp discharge, max 60.00 °C
