lgabc11865
http://secondlifestorage.com/t-LG-LGABC11865-Cell-Specifications?pid=9083
I got a lot of "refurbished" HP 9 cell 93 WH batteries that have a a nominal voltage of 11.1 and a capacity of 8100 mah.
They are new packs with maybe some shelf time, but they look great. The cells and the packaging is very clean
I opened one up to test the lgabc11865 cells and put them in my opus setup on the "Charge plus Test" mode at 1 amp charge/discharge rate.
After cycling, they give me between 1550 and 1750 mah. The voltage I see on them in this modeis around 4.15 volts.
So the data sheet linked from the database listing above says they should be 2800 mah nominal 2700 mah cells.
It also lists a constant charging voltage of 4.35 V.
Would I see another 1000 plus Mah If I charged them to 4.35 V?
I am going to try it but I was looking for thoughts of the community before I tried it.
I'm not quite sure how to dial in 4.35 volts on my Imax b6. I don't think I can do it on the OPUS.
If I charged them at the 2S level at a low current, I could watch them until the voltage got to 4.35 Volts, but that is not the same as charging them to 4.35V.
maybe at 200 mA they would be close to the 4.35.
Ultimately, I am wondering if they are fake cells.
