I have had a few large format Lion and Lipo's that have had a gas build up under the outer plastic wrap and cause it to look puffed but they really are not. I dismantled one of the power pack batteries that looked this way even with a thicker plastic cover attached. Once I exposed the flat packs, they were not puffed at all, in fact, they look completely normal and were still at their factory thickness with no puffing at all! I also have a couple of drone batteries (Larger Drones) that have this same effect but when you glide your finger down the plastic wrap of the outer battery area that does not have a heavy plastic casing the puffed plastic is just gas trapped under this plastic and again there is no real puffing. I have had real puffed batteries before and the surface is much harder and cannot be pushed down easily.
Is this gas venting other's have seen before?
