Lishen (LS) LR1865LA Cell Specifications
TheBatteries
Brand:Lishen (LS)
Model:LR1865LA
Capacity:2000mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
2000mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
2000mA Standard
--- mA Maximum
Description:Green Cell Wrapper
Grey Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Found 10 of these in 2021 Ryobi 18V 4Ah pack (PBP005). Grey wrapper, white ring. Supposed 10C max drain, so 20A max discharge.
Another 20 in a 40V Ryobi OP40401 from 2021. Cells are in great shape, BMS gave out because a solder tab broke loose.
Battery model: LR1865LA
Battery Color: Turquoise Green
Rated capacity: 2000 (mAh)
Rated voltage: 3.6V
Charging current: 4A or 1C
Charging time: 0.5 hours
Factory voltage: 3.6V
Load voltage: 4.2V
Battery internal resistance: ≤18mΩ
Working temperature:
Charging: 0°C ~ 45°C, Discharging: -20°C ~ 60°C
Storage temperature: -20°C ~ 60°C (1 month)
-20°C ~ 40°C (3 months)
-20°C ~ 25°C (12 months)
Battery size: 18.3×65.0 (mm)
Battery weight: ≤45 (g)
Battery use: electric bicycle, scooter, power tool, electric scissors, code scanning gun, flashlight,
Mobile charging power, communication equipment, unmanned aerial vehicles, etc.
Estas son en un inflador Xiaomi
