Lithium Iron Phosphate
Yes you can swap out the current BMS to batrium and it would work fine in 48VDC setup.
Using the current bms when having multiple in series is not recommended.
So here are the results of the test on these K2batteries.
This is a sample of ~70 some batteries.
I tested the 5 I took with me. What do you think?
Worth it or not.
Looks like there's some good capacity to be had?
Only 1/5 with higher IR/lower capacity?
I'd buy the lot if you can use them...
friedpenguin
Resurrect the dead! Batteries have been doing well. I have at least a dozen wired up with the off grid solar greenhouse aquaponics system. If my wiring wasn't so scary I'd post a pic or start a thread in the projects side of things.
