Look what i got to dismantle! hehehehe
m6yru
with thanks toKorishanfor the idea to contact ebike shops ::D i had to carry these home from work where the guy delivered them
i will dismantle the first on the left, the chunky one
the first battery i dismantled i got 50 cells from, took about an hour to strip it all down... that tabbing stuff really cuts so easy and when on codeine you dont even feel it!
nice samsung 2000mah cells, most are sitting about 1.6v, some are almost 1.1v and others are 2.2v
Hahah, wow!! That's a nice haul for the first run! :D WTG!!!
m6yru
now, i just processed another battery pack, took 40 mins...
it was one of the long ones that felt extremly light compaired to the other long one
this one was so easy to get inside!
WOO another 40 cells!
on average the voltage here was 1.6v, the ones front right was 1.4v - 1.5v but the front left was 1.9v!
i havent found what these are just yet lol
m6yru
spent an hour breaking more down, sigh, what do i do with the li-po pad cells? i got 2 so far and maybe another 2 in the other packs???
pack one flat li-po
pack two flat li-po
this is my next battery pack i opened up, next batch to sort out
WOW! :exclamation:each one is 3.9v! samsung 2600mah cells!
m6yru
well another battery pack and yes, its the flat li-po
sigh, another flat li-po
interesting....
the whole board is covered insiliconresin
well i got these tabs to remove, they're a nightmare!
they all measure 2.40v-2.55v
the batteries are pink cover, no text on the pink but on the shell it says AFFRE26 105255, nothing in the database....
only 1 pack left but at 6:30am im going to sleep!
DarkRaven
That's awesome, I was about to ask some bike shops as well!
You can use the LiPos for any other project. See how many you have of any type an figure out what they can power. I use a self made fume extractor for soldering for example. It runs on four 18650s, but it could also run on these.
You could also put them together to a pack which is rather flat and about the size of your laptop. Put a DC-DC converter of the appropriate voltage in there and you have a mobile, external power supply for your laptop.
And if I think for a little longer I can probably come up with some more idea, surely there is tons of stuff that these can be used for.
Hrmm.... I think I should get a cut of your haul ;)
Nice work. As DarkRaven said, plenty of other projects you could use those lipos with.
Abarth595
I like the ebike packs too.
If you get to know the brands in your area, you'll soon get to know which ones have lipo and leave them there.
It's just nice not having to clean the cells...
Try to find "local" "quality"bikes, they usually have better cells inside than the Chinese ebikes.
In Europe go for Batavus, Giant, Haibike, Gazelle, ...
One solid brand which works with the "ion" system do have pouch packs inside.
Older ones often have still NiMH cells in them.
happy hunting...
m6yru
thing is they scare the hell out of me with how volatile they are... there is so many safety things with these 18650 that im much happier about..
making them flat for laptop id need a sturdy box as im very agressive with my laptop and they could get punctured, id need a dc cut off and a buck converter that can handle at least 5amps however i cant connect that to my externalpower socket due to dell use propiety data transmission to their chargers, (3 pin plugs, + and - with a data line) this is what makes the laptop "charge"
my other project is to make everything in my bedroom 12v... i got a boost converter for the laptop then found my problem... the only things in this room thats not running 12v is 1 monitor and this laptop, and in the winter a fan heater
Abarth595
On the Lipo, I must agree. They are much more vulnerable due to thin skin.
Also when ageing, they start to expand. Even to that extend that some of the hard plastic casings from ebike pop open...
When I flew my RC helicopter, I had the Lipo's in there, and the cheaper ones expanded after only one season. The more pricier (brand names) ones lived a longer live, but they all expand over time.
I have a kind of "volt" for putting them in. It's a heavy metal case with a vent pipe on it, so if something would happen, my house would probably be still there...
