harrisonpatm
- Jan 5, 2022
- 438
Typically when we test a cell, we'd perform a charge-discharge-charge test, in which capacity is recorded during the discharge cycle. This makes sense as it's possible that the cell in question may have minor-to-major self-discharge issues, so we'll get a better idea of the cell's capacity if we can be sure that the cell is 100% full voltage, and perform a full discharge immediately afterwards.
Here's my hypothetical. Let's say I have a cell at 2.5V. The manufacturer's specs list this as a 3200mah cell. I charge this cell. It took 3200 mah to reach 4.2V. Can this be taken as a capacity test as well as if I had done a discharge test instead? Can I treat this as a 95-100% SOH cell? (Spoiler alert: it's not a hypothetical, I have acquired a large batch of the same manufacturer's cells and am wondering if I should alter my normal testing procedure for just this batch of several hundred cells)
Assume that I will also perform an IR test and check that against original specs as well, and assume that I will hold my 4.2v cell for 10-30 days and check voltage again after that time, to check for self-discharge issues. Because of course I will. My inquiry is wondering whether I can trust capacity recorded during a charge cycle rather than the usual habit of doing it on a discharge cycle. Looking forward to opinions.
