Megacell Charger firmware V4.3.0.11 reboot loop
enki
Hi guys,
I have been experiencing one of my Megacell Chargers rebooting in a loop and not being usable because of this. The symptoms are that the display shows "Display test" and the fw version, then the charger connects to wifi successfully and a message "Mc6 Init" appears at the bottom of the LCD. After this the device reboots and the entire process starts again. I have also captured USB console output and it shows the below messages:
Code:
  "Message": "Firmware V4.3.0.11"
  "Message": "Connection established."
  "Message": "SSID: <SSID>"
  "Message": "Password: <PASSWORD>"
  "Message": "Writing file: /settings.json"
  "Message": "Configuraiton file saved (56 Bytes)"
  "Message": "LogWriter initializing..."
  "Message": "LogWriter init is completed."
  "Message": "HTTPUpdateServer init...Hostname: FCF5C49724CDhttpUpdater setup...http update server starting...HTTPUpdateServer ready! Open http://FCF5C49724CD.local/firmwarein your browserand login with username 'admin' and password 'admin"
  "Message": "/index.htm file found!"
  "Message": "/workfile.htm file found!"
  "Message": "/edit/index.htm file  found!"
  "Message": "WOW! charger type: unknown!"
  "Message": "McC16 setting defaults"
  "Message": "Checking board details"
  "Message": "Checking board details completed."
  "Message": "McC16 setting defaults completed."
  "Message": "CRITICAL ERROR: Device stopped. Please contact thet support desk."
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Does anyone know what this means?
Needless to say I have created a support ticket with MegacellCharger Support but have not gotten any communication yet. It's hard to say whether the support script (https://megacellcharger.com/support/index.php) even works as it doesn't send out any e-mail confirmation with a ticket number when the ticket is created.
Oleksii
Mine boot messages on USB/serial console is this:
Default port speed in Linux is 9600 is set for new ports:
Code:
# cat /dev/ttyUSB0 | strings
2dO,4`lME
Firmware V4.1.8
SSID:****
Password:****
Configuraiton file saved (45 Bytes)
HTTPUpdateServer ready! Open http://6001943BAF4C.local/firmware in your browser and login with username 'admin' and password 'admin'
Detected charger type C:6-A:4f: Production
Reading all cell voltages...
Cell voltage for cell id: 0
Cell voltage for cell id: 1
Cell voltage for cell id: 2
Cell voltage for cell id: 3
Cell voltage for cell id: 4
Cell voltage for cell id: 5
Cell voltage for cell id: 6
Cell voltage for cell id: 7
Cell voltage for cell id: 8
Cell voltage for cell id: 9
Cell voltage for cell id: 10
Cell voltage for cell id: 11
Cell voltage for cell id: 12
Cell voltage for cell id: 13
Cell voltage for cell id: 14
Cell voltage for cell id: 15
FREEHeap: 23216; DIFF 23216
Setup complete. Moving on to app loop.
Never (recent) firmware requires port speed 115200:
Code:
# set
# stty -F /dev/ttyUSB0 115200
#check to make sure it's set
# stty -F /dev/ttyUSB0 speed
115200
  "Message": "SSID: ****"
  "Message": "Password: *****"
  "Message": "Configuraiton file saved (45 Bytes)"
  "Message": "HTTPUpdateServer init...Hostname: 6001943BAF4ChttpUpdater setup...http update server starting...HTTPUpdateServer ready! Open http://6001943BAF4C.local/firmwarein your browserand login with username 'admin' and password 'admin"
  "Message": "Detected charger type C:6-A:4f: Production"
  "Message": "Reading all cell voltages..."
  "Message": "Cell voltage for cell id: 0"
  "Message": "Cell voltage for cell id: 1"
  "Message": "Cell voltage for cell id: 2"
  "Message": "Cell voltage for cell id: 3"
  "Message": "Cell voltage for cell id: 4"
  "Message": "Cell voltage for cell id: 5"
  "Message": "Cell voltage for cell id: 6"
  "Message": "Cell voltage for cell id: 7"
  "Message": "Cell voltage for cell id: 8"
  "Message": "Cell voltage for cell id: 9"
  "Message": "Cell voltage for cell id: 10"
  "Message": "Cell voltage for cell id: 11"
  "Message": "Cell voltage for cell id: 12"
  "Message": "Cell voltage for cell id: 13"
  "Message": "Cell voltage for cell id: 14"
  "Message": "Cell voltage for cell id: 15"
  "Message": "FREEHeap: 20464DIFF 20464"
  "Message": "Setup complete. Moving on to app loop."
Yes, I can switch between firmware versions downgrade/upgrade. Because of a very bad ESR reading algorithm in recent firmware V4.3.0.11.
Described here https://secondlifestorage.com/index...ing-and-reverse-engineering.10493/#post-78625
Oleksii
What is your MCC manufacture date?
Is it in plastic case? Or older one without case? They have different PCBs.
enki
My MCC is in the plastic case. It's been purchased in 2021.
enki
This is clearly missing in my output and I think it's the reason for my problems. I think that MCC has a special descriptor block in the flash memory where the board/charger hardware type and revision are encoded. Could you dump the entire flash from your device so that I can compare with what I have?
Oleksii
I wanted to try that some time ago, but had not good reason for that. Now I have it!
It will take a few days for me.
Oleksii
I had no time to do that and due to the war of russia against Ukraine, I'm not sure when I'll be able to do so.
