Hi All,
After starting my powerwall project a 2 months ago, i replaced my cheap Xtar tester for a MegaCell Charger.
With the MCC i already tested around 800 cells, and decided yesterday to retest the cells i tested before with the Xtar.
Now, i noticed that the measured capacity with the MegaCell charger is mutch lower than i tested with the xtar.
I decided to change the default workflow to:
LVC Recovery
Charging (not in original workflow)
Rest 5 min (not in original workflow)
Mcap test
Rest 5 min
Low cap test
The Mcap test will charge the battery as well as the first charge task in the workflow.
My assumption was that one charge job will fully charge the cells, but during the second charge (in the Mcap test job) there is a lot of charging capacity left, for some cells over 300mAh.
The capacity result between the original workflow and the custom workflow is really noticeable.
This all leaves me with a few questions:
1. How reliable are the MCC results?
2. What is the best workflow, to get reliable results without losing to much time (sure, I can do 4 cycles, but it will cost me a day per cell, maybe there are other options).
If you have a MCC: Show your workflow
Thanks!
LVC Recovery
Mcap test
Rest 5 min
Low cap test
Thanks!
