Minimum amp
What is the minimum mAh to 'accept' a 18650 in your powerwall
  • 2500 or more
    Votes: 4 12.1%
  • 2000
    Votes: 15 45.5%
  • 1800
    Votes: 7 21.2%
  • 1600
    Votes: 2 6.1%
  • 1400
    Votes: 3 9.1%
  • 1200
    Votes: 2 6.1%
  • 1000
    Votes: 1 3.0%
  • 800
    Votes: 0 0.0%
  • all of them
    Votes: 1 3.0%
  • Total voters
    33
Do you mean mAh ? 2100 for me .
3nergE
I base my min off the original capacity of the cell. So if Im using new 1800s (like reclaimed replacment batteries) ill use 1800, but if they are say samsung 30b (3000mAh) then 2100-2200. I find that if its below 70% of the original the cells start to get a bit wiggy.
3nergE
I have to call back to my original post, dont do arbitrary capacity minimums, have a % of original design capacity as your minimum.
A 2100mAh minimum on first a cell that was 3400mAh compared to a cell that was originally 2400mAh are two entirely different beasts.
By design, manufacturers slate 70% of original as their 'throw away' point. Im inclined to be more optimistic on cells that started at higher capacities.
The long and short is its a good idea to test what different cells do.
Lastly, remember that capacity also affects the C rates for charge and discharge, so as a cell declines you need to account for changes in tolerances to stop the cells 'falling off the edge' quicker.
kind regards
My good packs are 2000-2400mAh as i have thousands of them. But im also going to build some smaller packs of 1800+ when they ar done since i have plenty of those 2.
I would say it all depends on what you got and how much time you have to spare for building.
Crimp Daddy
I voted 2000, but I am trying to keep it 2250 or higher. Most of my cells so far are 2500-2900 mAh but those were the better ones I got from non-laptop sources.
