Mining bios where to find it?
Stomppa82
Asus Rx 570 Expedion. 4Gb non oc model, hynix memory mining bios where is download? Thank You.
Geek
I personally wouldn't flash the BIOS. You will void your warranty. Instead, do some mining benchmarks, and use something like MSI afterburner, to downclock the card till you find your sweet spot. Using an amp clamp on the PCI-E power connector is a good way to measure power consumption. Then if the card fails, you won't have voided your warranty as the changes are not permanent.
Otherwise there doesn't appear to be any BIOS available online, and experimenting with memory timings yourself, might bring you unstuck.
I have a whole bunch of std bios somewhere on a USB - the key word is somewhere...
Not hardly. There are plenty of sites out there dedicated to Mining Bios' and you can search the database with your specific card
foriala
I don’t know much about mining cryptocurrency, but I think we can use torrent trackers. It’s always got everything from games to photos and courses, so I think you should look there. There may be a Bios for cryptocurrency mining. I use The Pirate Bay, but I go through the mirror to enter https://proxy-rarbg.org/ because in my country this torrent is blocked. Try to see if you can find what you need.
I don't really understand mining, but try torrent trackers
Mining Bios' won't be located on Torrenting sites/trackers. There's dedicated websites for configuring and setting up mining software and gpu's with custom firmwares.
