My First 48V 6.5KWh Li-Ion Powerwall 🥰
I am trying to PWM dim about 8A of light strips running off 24vdc nominal so about 29vdc max. I figured design it for 10A for some buffer. I think part of my problem is I was trying to just upgrade the MOSFET on a burned dimmer I have running off a 555 timer. I was able to read the full 28vdc on the gate which seams problematic and I don't know the switching frequency or gate charge capacity and was reading a significantly higher ohm resistance across the MOSFET when on.
Resistance increases with load, if I remember well. That's why for higher loads you'll see more than one MOSFET on the circuit, in parallel I suppose.
I found a nice paper with the formulas to calculate dissipated heat VS Rds (on), a good reason to choose MOSFETs with a low resistance; IRFZ44N has a lower resistance of IRF540 (I have these two models on my desk)
Now after some more learning about MOSFETS I am thinking it is time to build my own circuit to run of an ESP32 so I can add remote control. Of course that becomes a big project and I need to decide what I want to use all the extra pins on the ESP32 for :)
What about ESP8266 (for e.g. Node MCU V3 or Wemos D1), costs less and has less pins. I also bought some ESP12, even smaller and less available pins, but needs some wiring (and resistors) to be programmed.
August Update.
Got to final testing phase: cell buckets are ready, copper busbar, wire fuses and spot welding.
Goal is the always the same, happy I got it set right during first phase of the project:
4x 14s20p batteries, 280 cells each, 1120 total cells. Cells are second hand ICR chemistry, possibly 90% SOC, range 2000-2400mAh, IR range 30-70mOhm (yes, I know @Wolf it's a big range) and a small percentage of INR cells (with lower IR, too) to evenly distribute in packs.
Cell buckets
I have a load of boxes full of cells and labels... 1016 cells ready, 47 in rest period (10 days), 57 missing cells for 1120 target. I would like to have neat single-kind of nice plastic containers but, instead, I have dirty old cardboard recycled boxes. So I'm in a love-hate-love-hate-love condition ehm LOL. Just over 1000 cells selected and tested (some reshrinked, too) and I can do a good round-robin picking of the cells to make the first (of four) battery.
  • Buckets are divided in mAamps ranges and IR ranges: 2000-2099, 2100-2199, 2200-2299, 2300-2399. IR ranges 20-29, 30-39, 40-49, 50-59, 60-69.
  • Currently tested total capacity is 7706KWh.
Cell distribution
Bucket 2000-2099: 278 cells. 27.36% of total cells. 570Ah. 2109KWh.
Bucket 2100-2199: 371 cells. 36.52% of total cells. 761Ah. 2814KWh.
Bucket 2200-2299: 329 cells. 32.38% of total cells. 674Ah. 2495KWh.
Bucket 2300-2399: 38 cells. 3.74% of total cells. 78Ah. 288KWh.
Copper busbar
Oh my... I have stranded 16mm2 copper wire. After seeing those good videos from @hbpowerwall pulling solid copper wire nice and tight I realized my copper was stranded... hundreds of super thin copper wires to make the busbars. Ok, tried last night until early morning and got a decent result. Obviously I checked in the forum if anybody had used stranded wire for busbars (y)
Spot welding
Yee it worked! I was really concerned about the results of my previous tests: it worked well on nickel strips but not on 35AWG fuse wires (small explosions with hot-micro-metal-balls flying everywhere -and welder's copper points ruined/burnt at every test).
I don't know what the problem really was so I just proceeded with making a setup board and et voilà it worked. This will be really time-consuming until I find a fast way of moving around and solder fuse wires. I suppose it's a matter of experience.
I will be careful in pulling the stranded copper as tight as possible and without leaving any loose wires. In the photos there's my 74Ah car battery from my wife's old car and my 13€ AliExpress spot welder (put in a black box). Ah, and my lovely new 150W welder, love it!
Next steps (make first battery):
  1. Make 15 busbars (2 small ones for terminals blocks and 13 double ones to connect each block with the next one);
  2. Round-robin pick cells from buckets to make 14 series and mount them in 4x5 cell holders; 7 modules will have + on top view, 7 will have - on top view;
  3. Mount busbars on holders and lock with plastic strips;
  4. Spot weld fuse wire on cells using painter tape to keep busbar in place (stranded wire tends to move more than solid copper).
There's a step I'm not sure about: checking each series capacity; that is a 20P block for which I already know the single cell capacity. Lets say I do check each series capacity: 44Ah, 43.1Ah, 44.2Ah, and so on. Does it really make sense measuring each series? Just for and extra control or what?
Testing before building the battery is a perfectly rational thing to do.
On the other hand, I don't but that's because (in my process) I make adjustments after the BMS (Batrium) shows me the sagging packs after they are online.
Great progress, thank you for sharing :)
Ok, it makes sense. Will cost some extra work because I must test the single packs before mounting the busbars.
I could make two ad-hoc connectors (a sort of panel to cover the 20 cells in the 5x4 holder) for positive and negative sides and do a C-D-C cycle using a 12V 20A PSU and a powerful enough step-down board. Uhm, I think I'll cut open dead cells and keep top part of the cell, put them in a 5x4 holder, solder them all together and make a specialized connector for testing purpose.
I'll make mAh measurement using an Arduino and the circuit+code I posted in this thread with a 0.1A accuracy. I didn't buy a high-amp lithium charger/tester because entry level ones looked very bad in reviews.
Thanks a lot!
My suggestion for spotwelding fuses to 18650 cells is, to use proper fuses and not a fuse wire.
The fuse-wires are made out of lead (or at least i think so) which is pretty annoying to spotweld to certain kind of other metals.
I bought me 1000 3A fuses of that kind on aliexpress and i am yet searching for a material to spotweld them against as a busbar. You can however solder them easily to your copper wire busbar.
The fuse wire used most here is tinned copper wire 30-35awg. glass fuses are great but awkward to work with, keeping the legs the same length can be a problem. Cell level fused nickel plated steel strips are handy.
Later floyd
To blow at the same amp value the fuses need to be the same, the length might increase the amp when longer, decease when shorter. Perhaps I am mistaken wouldn't be the first time. Tinned copper wire is the same length or close to the same length when used as fuse wire. Cell level fused nickel plated steel the fused part pf the nickel is the same length for all the cells.
Later floyd
Are there any tricks you have for spot welding to bus bars? I am using 4AWG solid coper wire as a bus bar for some packs and am trying to attach .15 nickel strips to the bus bar but the KWeld wasn't melting on well even all the way up at 200jouls. I would rather not have to solder it on but that is my current plan unless you have tips.
Sharpen Kweld tips to a finer point? How wide of a nickel strip, perhaps try a narrower strip? or use tinned copper wire. Very small contract area of the wire while still providing ample current capability.
Later floyd
Not yet, I still have to find ways myself as spotwelding directly to copper is a bit hard.
October Update
Quick update after a month break, I switched onto a new client, tough time!
1) Ordered a more serious spot welding machine to make my battery packs, batteries are laying on my desk since August. After watching @hbpowerwall review (hilarious! LOL) I decided it was ok and in my budget: 709AD :love:. Yeah! I just really could not do more than 10 cells without serious sparkles using my 10$ AliExpress Spot Welder.
Found a good price (just below 200€) and don't pay customs or extra taxes because I can get it from Czech republic :cool:
2) Will be using my solar 1.6KWh + 18650 battery pack to power... my (new) mining rigs :giggle: Got wife approval LOL(*) so now it's official, she agreed to expand the system with a new video card every month, that's fine with me.
Mining, as we know, isn't profitable as it was some years ago, but... I make a bigger gain like this, instead of just powering the house with solar. There also is a certain risk with coins value...
This is a peak value, 3.24€/day (around 3.5USD/day), oh I love it! Average daily is between 6 and 7000 just below 6000 satoshi/day.
(*) This is what happened. On the beach this summer (in Sicily) we get to talk with so many people, friends and so on. Now, a friend of hers one day, was saying something about these Bitcoins she had, worth 40K each... so my wife remember I had a Bitcoin back in 2011 and went on asking me about that for days on... And I was, you know, ... "I don't know", "Can't remember"... She was so attracted by this crypto-stuff that I proposed doing mining with solar and she said immediately yes. Wow, lets go!
Later floyd
The fuse is located in the glass container, the wire inside is (or should be) much smaller then the legs which are connected to the battery. The power drawn trough the fuse will thus be the same for alle fuses, regardless of the length of the wire to the fuse, otherwise the fuse would 'blow' outside of the glass container and still be a fire hazard. And this hazard is exactly why you would switch to these type of fuses instead of bare wire.
@italianuser following your thread to see how you're handling the new spotwelder. I borrowed a kweld from someone in the neighbourhood to get started. I'll be posting my initial thread (hopefully soon). Still have some questions and need some recommendations for building my initial setup. I ordered 600 3000mah cells from fogstar (0.25 pound per cell, without VAT and import duty). I've put some of them in my tester to find out their initial capacity. I'll post more info in my thread ...
Wow, that seems to me a good price for the cells (y)
I'm still waiting for the spot welder, they haven't shipped it yet. Shipping time says 4-10 days, I do hope they will send it. Lately I've been having problems with AliExpress in buying other products with shipment from the UE (to Italy): I pay and they don't ship, I "(&%£"/&%$£/" and they refund. LOL
As soon as it arrives I'll share photos and test setup, yes.
Waiting for your post (and questions are always welcome as you know!):)
I bought old laptop batteries and effectivly paid 25 cents per functional cell aswell, averaging 2200mAh.
I also went with the same style of glass fuse, but after some initial testing, they dont seem that great overall.
The batteries or the fuses weren’t great?
The fuses, their legs break of very easily and in the end, you have to solder them to copper busbars anyway.
For the soon to be done rebuild of my first battery pack, i'll defenitly go for thin tinned copper wire instead of fuses.
Update July 2023: Battery test DONE with FV Panels, Inverter setup and 700W load. With minimal budget.
:D I finally did a full setup test, I was really delayed by:
1) The solar panels, mounting them on my balconies isn't easy because of the self-made metal structure which must be light enough, at the same time solid enough to survive 140KM/h wind (~95MPH only happens a couple of times a year, but it rips roofs off). My original plan wasn't good for the fact I was using metal bars for the whole structure, too heavy; the new project has metal bars for making an "L" shape to fix on the brick wall (not full bricks) and an aluminium part to hold the panels themselves;
2) The wife. Please use your imagination here!
For the test I simply put the panels on the balcony's floor giving the best inclination I could.
Setup configuration:
- One 14S20P 40A battery, 18650 cells are the ones I selected. 2000-2399mAh, IR 30-79mOhm, all ICR cells (no Sony V3, no ICR, no unknown cells). The second battery is ready and the third one just started; I don't have a busbar for the battery yet, that may seem a small detail but I must find an effective (and final) solution with what I have in my lab; Cables 16mm2 from battery to inverter;
- Hybrid Inverter 5KW to connect FV panels, battery, AC Input (it's my lower priority input source after Solar and Battery), AC Output to the 700W load; oh, I loved the inverter; cables for AC input and output are the standard here in Italy 2.5mm2;
- 4x 280W poli FV panels, 8.64A (Imp), 32.4V (Vmp), 39.0V (Voc), connected in series of two, the only configuration compatible with the 60-115V PV input of this inverter; for the test I connected 4 out of the 6 panels; not at the best inclination but the best I could get on my balcony without mounting the metal structure for now, maybe I reached 36-39° instead of the optimal 32° for my city. Orientation, not the best either, I have south and west orientations;
- Cables for FV: I had 10mm2 and 16mm2 for the 10mt (~30ft) distance from balcony to my room. So I used one for the negative and one for the positive (sorry, guys! It's a test!). From my formulas I'd have an 0.9V loss from the panels to the inverter using a 10mm2 cable. Depending on the price I can find, I'll chose 10 or 16mm2 for this wiring;
- Connectors: MC4 and SC10-6, possibly copper ones. In some points I had to use SC6-6 connectors, not full copper ones;
- Environment: outside temperature around 34°C (93.4°F), inside 3 degrees lower;
- Cooling: I don't think it's needed at all being the system inside.
Some photos.
Battery and BMS
Series are connected with 10mm2 copper wire. SC10-8 copper connectors, bolted together. I abandoned the cell-level fuse wire, too much effort for me to spot weld. So I chose a nickel strip solution and maintenance, if necessary, will be at pack level where removing a pack shouldn't be too difficult.
I will mount a relay to automatically disconnect a battery in a temperature or voltage anomaly situation. I bought 60A and 80A relays.
BMS is a dumb Daly 20A/40A (charge/discharge).
Nickel strips that connect series can carry around 20A. Fuses for each battery are 20A.
Spot welder: the Sunkko 709AD+ did a decent job but I did have some problems. Until now I did maybe 5000 spots and had a severe problem twice: the spot welder just wouldn't weld. I pressed the pedal and it reacted as if there was no contact between the two tips. I never changed the tips yet, they are quite used up, there only a few millimetres left. So, what I did was to clean the tips, disconnect all the wiring, connect it up again, wait a bit and it started working again. Uhm... And another problem I had, and I don't really know the cause is that I used the same settings for these first two batteries (pulse 10, amp scale setting 5.75) but on the second battery it couldn't make it, as if it lost power. I had to increase to pulse 14, amp scale setting 6 to get some decent spots.
Ah, I did find out something about nickel welding, nickel on nickel: I did cut the the nickel strips to connect the series and then spot welded them. Now, by coincidence, I cut a couple of strips in the other direction (vertically instead of horizontally) and... the welding can be done easier at a lower power. So I suppose the nickel molecules, at a chemical level, have an orientation (they're not round or symmetrical molecules / structures). Wow.
Panels and connectors
I then tilted the panels down to get them as near as possible to 32°, weren't really that "flat"; I could visually compare them to the other 4 small 50W panels I already had mounted and I was off by quite a bit, but it's OK for the test. The connectors had a really big impact, they were screwed up tight but I wasn't getting much power out of the panels. I tightened them really super-strong and it was ok. I think I'll avoid those connectors and bolt the wires up directly.
Inverter and connections
Black wires are 16mm2, blue ones are 10mm2. Minimal safety devices for the test, two 63A DC MCBs (I'll use 20A ones for the final setup).
With a 700W load inverter reported a 15% load.
First try to connect battery wires to the inverted without the MCB... connected the positive, ok; as soon as the negative touched the connected it sparked, did a loud bang and I jumped; I said to myself "I burnt the inverter!". But no, it was only that moment when a single strand of the wire touched the connector and sparked, that's no good. Use the MCB to connect the parts? Yes.
Final thoughts and results: I'm satisfied with the job, what a pleasure. What gets me is that nobody at my house can even imagine what's behind this DIY job, LOL 🤦‍♂️. Maybe I know one person, maybe two in all, that could share the pleasure with me! Of course, a part from you!
The battery is the biggest part of the work; and the details, in general, are really time consuming.
Output from FV reached a maximum of 55% of the nominal wattage (1120W) with full sun coverage, I think I can reach the full rating for 2-3 hours a day when the panel will be mounted high up on the balcony. Battery was cold during all the tests, 700W load isn't much at all; charging and discharging was what I expected in regards of the load and the battery capacity. Inverter worked first go, I did I quick setup, I'll give an update on what I didn't like much (for e.g. granularity in voltage settings, sometimes with 1V steps others with 0.1V steps). Cables cold during all test.
Next step, I'll have a week holiday in August dedicated to get things finished.
- Arduino/ESP8266 temperature control with DS18B20 ICs, already tested them in the "one-wire" configuration and they work perfectly; for temperature problems the Arduino/ESP8266 will disconnect the battery via a relay;
- Measurements: only DMM ones for this test and what the inverter told me. I'd like to have the measurements integrated in my website where the house measurement arrive for now (temperatures, AC loads and water tank level); I always have in mind @Wolf 's superb Graphana dashboard, If I have spare time, I doubt it, I'll look into it (I used it in the past, it's super simple, but... time consuming!);
- Inverter's Software, I have a CD with the software but haven't installed it yet.
Hopefully I'll get them mounted soon and will be happy with seeing everything nice and setup.
Yes and no. The reason you got a spark is that the instant you hook up the neg cable the capacitors on the inverter want to charge and they like to do it fast. So the best way to "pre charge the inverter" is to use a resistor to trickle the voltage and amps into the capacitors. For a 48V system a 30Ω 200W resistor will do just fine making the connection for about 10 seconds. If you have a high quality MCB like ABB you can get away with hitting it once or twice as it will reset because of the amps. 3rt time should hold. ABB MCB will take that punishment but many others won't.
No matter what though I recommend running the resistor much safer. Just get some alligator clip wire hook the resistor up and one end goes to the battery neg and the other end to inverter neg waite about 10 seconds and then throw the MCB to the on position, and all set.
