rebelrider.mike
- May 25, 2017
- 614
I don't use this tool often because the batteries are a pain to charge.
They're always dead whenever I need the tool, take a couple hours to charge, and only last about 20 minutes. Also, the original charger is long gone, so I use my universal.
The charger has a refresh mode where it does 4 charge/discharge cycles. I'm trying that tonight to see if it will help. If not, I may look into some lithium cells for it. If I could cram a 2s2p pack in there, the voltage range would be perfect, and it would run 3x longer. Depending on the cell capacity. Plus it would be charged when I need it.
Anyway, just imagining at the moment. I'll see how the NiMH batteries turn out after the refresh.
