Hi All
Ive started my new build project to build my "off grid as much as possible" project. I thought i would share as much as i can with you all.
I started with the design of the system, the schematic of the system, the BMS, and a way to mount the solar panels.
As you can see from the schematic, im using Victron equipment, a BMS by Bpath, and 40x 340w Solar panels.
Specs for the Victron Equipment (inverter/charge controller etc.)
Victron Quattro Sine wave Inverter/Charger. 48 volt 15000va
Victron Cerbo GX
GX Touch 50 display
Victron BlueSolar 250/100 SMART CHARGE Controller.
Victron Smart Shunt - 500A 50mV
Lynx Distributor Board - 4way - 1000A capacity
Canadian Solar 340W Super High Power Poly panel
Weatherproof enclosure to combine 6 PV strings
BMS - Its a new plug and play BMS for the Tesla battery that i was lucky enough to get hold of from a dismantled Tesla P85D.
Progress is being made, and i will give updates as and when i can.
Victron Cerbo GX
GX Touch 50 display
