my new project
dali1972
AT LAST !!!!!!!!!
I have power........
Im getting the batteries charged up...and doing a few final tests.... BUT my system is complete ...(cough...for now!!!)
Ellyse
Hi All
Ive started my new build project to build my "off grid as much as possible" project. I thought i would share as much as i can with you all.
I started with the design of the system, the schematic of the system, the BMS, and a way to mount the solar panels.
As you can see from the schematic, im using Victron equipment, a BMS by Bpath, and 40x 340w Solar panels.
Specs for the Victron Equipment (inverter/charge controller etc.)
Victron Quattro Sine wave Inverter/Charger. 48 volt 15000va
Victron Cerbo GX
GX Touch 50 display
Victron BlueSolar 250/100 SMART CHARGE Controller.
Victron Smart Shunt - 500A 50mV
Lynx Distributor Board - 4way - 1000A capacity
Canadian Solar 340W Super High Power Poly panel
Weatherproof enclosure to combine 6 PV strings
BMS - Its a new plug and play BMS for the Tesla battery that i was lucky enough to get hold of from a dismantled Tesla P85D.
Progress is being made, and i will give updates as and when i can.
Wow, what an Outstanding post. I found this too much informatics. It is what I was seeking. I would like to recommend you that please keep sharing such type of info. If possible, thanks.
dali1972
Hi Ellyse - im in the testing phase now... starting up the system and making sure everything works as i would expect it to..
I will post very shortly with this update... but if you plan to build a similar system, i would be more than happy to help with what i have learnt...know. But many of the members here have a VAST knowledge... and are all very welcoming.
