you could have told me earlier that I needed sun to run it....Congratulations! 43w? Don't forget to turn it on (ha ha)
Hi Ellyse - im in the testing phase now... starting up the system and making sure everything works as i would expect it to..Wow, what an Outstanding post. I found this too much informatics. It is what I was seeking. I would like to recommend you that please keep sharing such type of info. If possible, thanks.
Congratulations! And this should continue, year after year - solar is soooo cool.So far ive managed to produce 7440 kWh of electric.... and used as much as possible.
I'm offgrid and use ATSs to switch to grid (and back) as the solar/batteries charge up and down.The system was designed to be off grid as much as possible.... so winter was always going to be the big strain.
Will be interested to see more details on this if you post. I'm in year 4 of operation and have only needed to do minor tweaks to my 18650 packs so far - but clearly operational issues are coming in time.2. System shutdown due to Cell imbalance - The tesla modules were second hand, and over a period it was seen that 1 battery showed a higher charge. This caused the BMS to shutdown the system.... It was a pain in arse trying to work out why it happened, but this clearly showed the BMS worked well. This is a post all on its own.... as i took pics of the cells...alarms... and graphs to show exact cut off point... and recovery actions. (had to switch house back to grid - how bloody awful !!!!)
4. One module faulty.... have had to alter the total charge on the battery pack... so may need to consider taking out the offending 18650's or just replacing the pack - still not done this yet...
Yes sir. I'm at 45 panels (13kw PV) and opting to add 15 more / just loose power in summer to have more in winter. In the early days this would have been unthinkable but I'm more about offgrid/winter-power these days and will never recover my $ in any case - so it's less of a mental issue for me these days.Down side to the system... during winter need more power during night to cover lack of full charge on batteries, during summer need more batteries to cope with load.
Will be interested to hear how this works out.I plan to make a wind turbine... so thats the next step, as i think this will be cheaper than buying more batteries...
Hi , in what material is the white panel where the victron is attached? regards MBMy Power room install updates
Planned the layout, battery layout/position, and position and layout of the equipment.
Decided to install the DC side first... PS - OMFG the inverter!!! needed help to get it onto the wall and then needed time to recover from the Hernia i had just given myself.
Then it was onto smaller and MUCH lighter stuff.
Solar controllers/Distributor/Cerbo GX (the brains behind the operation) and a touch control pad for it.
And last but not least...the Bpath battery management system.
I have 4 different parts - 3 x single-phase, 1 x three-phase. I use manual switches at the mo, but im trying to make a semi auto system i can remotely control with an audino and actuators to allow me to control it via my phone remotely. Over complicated - yes...but will be fun.I'm offgrid and use ATSs to switch to grid (and back) as the solar/batteries charge up and down.
How do you integrate the grid in your system?
My system is 48V and had an imbalance to one of the batteries (modules)...so took 2 modules out... left it to rebalance over a week... and tweeked the system.Will be interested to see more details on this if you post. I'm in year 4 of operation and have only needed to do minor tweaks to my 18650 packs so far - but clearly operational issues are coming in time.
With the price of electricity in the UK now... its making a hatched(botched!!) system like mine able to repay itself within 3.5/4 years... but i never thought that would be the case when i made it.Yes sir. I'm at 45 panels (13kw PV) and opting to add 15 more / just loose power in summer to have more in winter. In the early days this would have been unthinkable but I'm more about offgrid/winter-power these days and will never recover my $ in any case - so it's less of a mental issue for me these days.
Thanks for sharing
Yes please dali1972Update on solar panels mounts.
These ones are for AJW.... close ups of the mounting straps to the poles.
The 60mm bolts did fit "Just", but the bolts i had were partially threaded, so i exchanged them, and got 40mm fully threaded bolts, that worked perfectly.
A new minor amendment added a support brace to the main leg instead at the end of the mount.
The mounts are changeable to vary the inclination during the year.
It just takes to loosen a couple of bolts, and the whole mount is able to be lowered/raised. Only managed to get one set up today, as i was testing it all out... and it works really well. You can adjust it on your own....its just alot easier and quicker with 2 people.
**** if anyone wants to make similar mounts, i have cad drawings that show all the poles, couplings, and pole sizes. I could also make up instructions once im complete and would be happy to send out to anyone, free of charge. *****
Cost breakdown for seasonal adjustablesolar mounts - my mounts were to hold 5 panels measuring1765mm x 1048mm
wood to make feet template - free using spare wood
49 ft of scaffolding pole 49.00 (got from a local scaffolder - who buys in bulk)
short tee clamp 2.85 x2 05.70
3 way through corner tube clamp 4.2 x2 08.40
single swivel tube clamp 4.95 5 24.75
single mesh panel clip 0.88 x13 11.44
m6 x40mm per bolt x 13 00.44
m6 washer x13 00.50
Timco Rubber Sela Washer 28mm x10 01.40
CARBON STEEL & NYLON EPDM WASHERS x 20 01.01
TOTAL102.64
