My project Solax G4 and ZOE 41 Dala Emulator
moustik
Hello dear members,
I've embarked on Dala's project. My photovoltaic system is equipped with a Solax Hybrid G4 inverter.
I bought a 41kWh Zoe battery.
I built my emulator, following, I believe, the instructions on Dala's GitHub to the letter.
I installed an insulator between the inverter and the emulator.
I connected the ground wires between the battery and the inverter.
I have no connection between the inverter and the emulator. The error messages are attached.
error message IE19
I checked every connection between the MCP2515 module and the LilyGo, and everything seems OK.
I should mention that I'm not skilled in programming.
Thank you for your help.
I measured the voltage present on CAN H and CAN L at the inverter output. I have approximately 2.3 volts across the terminals of the isolator module, using the Solax casing as ground (P.E).
I tried the same measurement on the connectors of the MCP2515 module. I have approximately 24 volts between H and L, using the battery casing as ground (P.E). This 24 volts is intermittent.
I ordered another MCP2515, this time with a ribbon cable.
here is the log
  • canlog_00-07-11.txt
I found the solution to my communication problem. I forgot to put the jumper on the MCP2515 board.
If you want to test your configuration, follow the link.
Yeah, I think most of us have done that simple mistake before :p Glad you found the problem tho, and that you reported back with the solution in case someone else has a similar issue.
