My Wall of Power
AZ_Tekkie
No new updates on the power system, but have made some more progress on my power shed.
AZ_Tekkie
CrankyCoder said:
AZ_Tekkie said:
And we're live. Made one design flaw though, the batteries stick out further than i anticipated and interfer with the door on the cabinet closing and locking. I'll have to do some slight fabrication to the door to get it back in working order.
What box is that? I like it!
You just need to find a electrical supplier that sells used and wholesale electrical stuff.
WebmasterHJ
AZ_Tekkie said:
My latest creation. 3d printed a case to house my volt meters.
Love your work man. I was wondering if you could show us how your wired your 7S battery monitor box to the RJ45 connector and how you wired theethernet cables? Thanks alot
AZ_Tekkie
Thanks. I no longer use this to monitor cell voltage, switched over to using the batrium bms. I can't recall how exactly i wired it, but just went pin to pin. 7 cells so you have pin 1 negative most and then the next 7 pins go to each cell bank.
gregoinc
Thingiverse link:http://www.thingiverse.com/thing:2187073
Came across your thread,love the build, andvolt meter setup. Have been searching for a meter like the one at the very top. Any chance you could share where you sourced it from?
AZ_Tekkie
If you go to the thingiverse link, it lists what all was used to make that meter.
AZ_Tekkie
Only 3 years in the making, my Power Shed is finally up and running. Currently only have the first pack of about 12kwh installed, working on the second 12kwh pack. Inverters are MPP 3048LV running in split phase. 10 solar panels on the shed roof, about 2.8kw.
jdeadman
Very nice setup.
koshaymacky
Updated photos (02/04/2018)
Current Wall 2.0
stranger chatting app
Newest Pack using LG G5 Cell Phone batteries. Should be around 5.5Kwh. Will be installing soon, have the case they're going in ready, just need to mount the pack inside.
Start of my new power shed. 11ftx17.5ft. Will be for my power wall and either storage and/or an office if i decide to finish the inside.
online chat portals
Charging Setup
That looks fantastic reminds me once we start cracking we should have a Setup of the month like some other forums do
