need help again
julien
good evening it's me again, I had his batteries whose capacity will be 2200mah, but will you have a page for his batteries? because impossible to find with what it and mark above thank you in advance :) sorry my google trad is bad lol.
It could be this one - https://secondlifestorage.com/index.php?threads/sanyo-ur18650fj-cell-specifications.1712/
However - I agree its likely 2200mah/cell at 100% and as long as you're only planning lower drain use (e.g. 500ma'ish/cell charge/discharge) as apposed to high drain (2a, 3a, 4a, ... /cell) - then you should be good to test it as if it were a laptop level 2200mah cell with standard specs.
julien
Ce pourrait être celui-ci - https://secondlifestorage.com/index.php?threads/sanyo-ur18650fj-cell-specifications.1712/
Cependant - je suis d'accord qu'il est probable que 2200 mah/cellule à 100% et tant que vous ne prévoyez qu'une utilisation de drain plus faible (par exemple 500mah/cell charge/décharge) par opposition à un drain élevé (2a, 3a, 4a, ... /cell) - alors vous devriez pouvoir le tester comme s'il s'agissait d'un ordinateur portable de niveau 2200mah avec des spécifications standard.
Okey 🙂 thanks chuu
