OK... I'm building an E-kart to go at least 60mph. I bought an Alltrax SR72450 controller, sw202 selenoid, 5k throttle today. The problem is I will have to mount everything after receiving it which will cost more money in materials. Then I came across a Curtis controller already mounted on a heatsink plate, neatly done with copper bars and with all components needed on eBay for under $600 (link listed below). I'm wondering which controller would be better for my setup and is it worth keeping the Alltrax and mounting everything up or return the Alltrax controller (which costed me more) and buy the Curtis controller? Will I get the same power and efficiency out of the Curtis as I would out of the Alltrax? THANK YOU FOR YOUR RESPONSE AND HELP!!!!!
https://www.ebay.com/itm/CURTIS-Controller-1205M-6B403-Assemblage-60V-72V-with-Throttle-foot-pedal/112893890218?epid=2072789018&hash=item1a49000eaa:g:7qIAAOSwT-FZCD7c
Kart Weight with everything besides the motor: 120 pounds
Rear tire: Mojo 7.1/11.0-6
Gear Ratio: 2
Motor Sprocket: 18t
Axle Sprocket: 36t
Battery Setup: 2x 40V 18.4AH 736WH LITHIUM LIFEPO4 96 A123 26650
Motor: 72v Motenergy ME-1003
Gear Ratio: 2
Motor Sprocket: 18t
Axle Sprocket: 36t
