New chineese bms with 1.2a balance
Looks a smart little board. Note that it can most likely NOT sustain 1A balancing current for any longer period of time. They only have 1 resistor per port at 3.3ohm and imagine balancing at that rate on all you would get a whopping 42Watt. Impossible to get rid of that heat fast enough :)
So I would say concurrent balancing current is most likely around 100-200mA per port but still nice thing!
Interesting arrangement, too. It's nice that the balancing traces are much heavier than the others. So there was actually some forethought put into the board design.
Nice find :)
jdeadman
Very nice idea but I agree with Daniel, 1A on those little resistors will blow them up pretty quick. I use 3 Ohm 10 Watt Resistors (the big white bricks) to manually pull down cells that are too high before assembling a pack and they draw just over 1A and I can only run them for about 20 min at a time before they get too hot.
But if they had a really good heatsink and a fan they might work on a lesser duty cycle
higher_wire
Discharge current is only 20a. No mention of charge current, but Id guess the same?
