We may circle back with you when we get up to adding that logic, if you don't mind.Lovely
Using my bad sample data to build a pack, results in wrong numbers for the capacity.When i'm copying my cells capacity out of excel and put it into repackr, each capacity will be seperated from each other.
When put them into your tool, i get one long number out of them, making your tool unusable for me.
Repackr also has no issues, with wrong data like this:
2081
dead
dead
2319
1981 H
1970
2349
Hey have those changes made, amp hours and watt hours should be fixed.Using my bad sample data to build a pack, results in wrong numbers for the capacity.
I'm not good in maths, but wouldnt divergence be twice the number it currently is?
Jeff and I agree too, we spoke about it and added the change to our to-do list for this week.I think the whole number would make more sense, because in the end you're missing out on 268mAh which in this example is already nearly 2.5Wh.
Just wanted to let you know, the change has been made. Working on a few more changes/improvements which should be released in Early December. Thank you for your feedback!!I think the whole number would make more sense, because in the end you're missing out on 268mAh which in this example is already nearly 2.5Wh.
Added to our notes!! Thanks for the suggestionFor the solar part, maybe you can implement something simmilar to: https://re.jrc.ec.europa.eu/pvg_tools/en/#PVP
Can you tell me how this tool calculate the parallel string average IR? Can you share the fomula with us?The IR balancing functionality has now been added to our packer tool!!
Please let us know if you catch any bugs or errors, thank you all again for your support!
Hi, Thanks for the explanation. I just put some test data (1000:10,1100:20,1000:30,1100:40) into the tool and checked the outcome. It just tells the avarage of IR values but not showing the actual parallel resistance of the specific cell set. 40miliohms and 10miliohms should create 8miliohms parallel resistance but the tool just shows the avarage of two values. I just need to know that is it using the IR values to suggest the best possible combination or just based on the capacity balancing between parallel sets.
@frankonline
Not sure how @Kakakee website does it but there are many tutorials on this.
The basic mathematical formula is as such:
Also a bunch of videos explaining.
https://www.youtube.com/results?search_query=calculating+parallel+resistance
Thank you so much for supporting us!! We won't let you or the community down!!!
Just checked and it was working fine for me. What was the message you got when trying to go to the site?Site is down?
Connection timed out. Both Firefox and Edge. Now it's back up again.Just checked and it was working fine for me. What was the message you got when trying to go to the site?
I know Jeff was pushing out an update, he may have been merging his staging branch with the live branch when you landed on the site. Apologize for the inconvenience, glad it's working now!Connection timed out. Both Firefox and Edge. Now it's back up again.
