I just bought a Segway for cheap - cheap cause the PO said it needed batteries. It has two lith-ion batteries, each being 73.6V 6000 mah, each made up of 92 LifePO4 (3.2V @ 1500 mah 18650 each) cells in a 23S-4P setup.
When I first got the Segway (which wasn't charged in a long time), each battery had ~75V so I plugged them into the Segway's charging port - after 10 hours I saw one of the batteries flashing green (the manual says that means it was charged and in good shape) but the other was red (again in manual suggesting the Segway or BMS found an issue and stopped charging it). I tested them again with my multimeter and now both were ~84V (which confirms the built-in charger works, and that the cells are charging to their full range - but again odd that one battery was flashing red). So I tried the Segway and it does show full charge on the display but after a minute of average to high speeds it auto shuts off with a battery warning - though if turn unit back on I get the full battery display and again works for a minute and then shuts off.
So being they both charge up to their full voltage, I suspect some of the cells are dead or not accepting enough capacity - hence why the Segway gives me the full battery display (cause the voltage is 100%) but dies cause of low amps (capacity). And being the batteries are grouped into 4 bundles (in parralel) with 23 of them connected in series, being I get the full voltage this would suggest at least 1 battery in each bundle is good (though my guess would be most bundles are good, or most have only 1 bad cell and 3 good ones).
So I want to try and tackle this myself. I am a newb, but very handy in general, and have tinkered with electronic repairs but never direct with battery packs. I have spent the last day on google and youtube and think I can handle this, though at same time realize these can be dangerous. That is why I'd like some advice.
I'd like to know the best way to diagnose the pack. I really don't want to take each battery apart into 92 cells and test each one separate. Looking online it can take a few hours per cell to test the mah, so I don't want to do it this way. Is there a way to test each bundle of 4 - each bundle should be 3.2V @ 6000. I have a imax B6 that a friend lent me - can this be used to test the capacity? If so, can I use this device to test more than 1 bundle at a time? Can I somehow test two or three bundles together. Here is a link to the same battery I have for reference.
View: https://www.youtube.com/watch?v=B7T9SISua8s
Thanks
Thanks
