Okay, this seems pretty cool. Wondering if anyone else has seen what battery hookup is selling now? https://batteryhookup.com/collections/cell-level-nickel-fuse
I had the same thought, but then figured you would only use this on the positive side and if a cell needs replacing, you would push it out the other side?chuckp said:Looks interesting.
Could be an issue if I needed to swap out one rouge cell though.
Looks like it would be a full strip down of the pack.
Oz18650 said:I had the same thought, but then figured you would only use this on the positive side and if a cell needs replacing, you would push it out the other side?
Then spotweld a new fuse with its surround into place.
Generic said:I give it two months before China copies this and sells it as a nickel-plated steel version at 2 cents per cell.
boysie said:mine has arrived, but didn't think about how to cut the sections, in my case 8 cells long. I'm guessing tin snips but any other ideas?
chuckp said:Oz18650 said:I had the same thought, but then figured you would only use this on the positive side and if a cell needs replacing, you would push it out the other side?
True, but i think both sides would be better for the pack aesthetics
Also if going to the effort of making my busbars for one side I might as well just do both sides the same.
Would be great if they could make one specifically for the negative end with a wider opening.
CrimpDaddy said:chuckp said:True, but i think both sides would be better for the pack aesthetics
You know you are a battery enthusiast when pack aesthetics become a thing lol.
cowpen said:I emailed batteryhookup twice last week asking if these are pure nickel and what thickness. No response. Anyone know?
Product Details said:These are continuous rolls of nickel steel 6 cells wide
