Yes, I know it's time consuming. But characteristics will be different.
I'm not sure what wire you used here for fuse, but having some experience and looking in the picture I guess it's 0.4mm in diameter, ~10 mm long.
If that is tinned cooper, each connection is ~1 mΩ resistance, current to burn it would be 50-60 Amps.
Your cooper bus but is really solid, maybe oversized. How many mm2 section those twisted bus bur cables?
I'd evaluate the bus-bur as contributing ~0.5mΩ or less resistance per one side. It's hard to express that but this number is good compare with cell and fuses resistance.
Note - per data from
@Wolf fuse on the nickel strip has ~22 mΩ resistance. If I understood it correctly - sheet of 50P (5*10 cells): 20сm length has 5.5mΩ.
So Wolf used cooper bus bur on top of the nickel sheet, see here
https://secondlifestorage.com/index.php?threads/wolfs-powirwall.7804/#post-61125
All these details contribute to resistance, so you should consider that.
p.s. I use very thin tinned copper wire on positive side, 0.16 mm in diameter, ~10mm long, has ~10 mΩ resistance, burns at ~12-13A current which I tested practically. On negative side I used thick wire - 0.5 in diameter, ~6-7 mm long, has 0.75 mΩ resistance.
Bus burs to collect current 3*2.5=7.5 mm2.
