elkooo
- Aug 9, 2019
- 32
So this is going to be the introduction:
Currently I am still in consideration / battery-harvesting / planning process.
What already exists:
Photovoltaic installation with a 3phase grid tie inverter that runs on around 600vdc (up to 1000 possible) and converts all the solar energy imediately to AC.
Our house has a 3phase 380v system (single phase to neutral is 220~230vac).
The plan for now is to start with a single phase 1kw battery inverter.
I would like to build a 14s32p battery with around 5kWh capacity for starters to gather some expirience and learn how to deal with batteries, bms, chargers and everything else needed to safely operate a powerwall system.
I planto connect a first single phase systemto the one phase that sees the largest nightly power consumption (need to measure all phases for a certain period). The system should then charge at daytime (while excess energy from solar panels is available) and discharge at night through the additional inverter to cover the consumption we have.
Later on, a second battery & inverter combo can be added to a second phase and subsequently the same to the third phase. (Can't use the same battery because of common-ground-problems --> phases will possiblybe connected through the inverters and burn them when operating from the same battery system so better to have separate systems for now... and later on maybe replace the inverter with a 3phase-solar & battery inverter)
I do not plan to touch the PV-Inverter right now since this one has no battery capabilities. If it reaches his end of life, I might replace it with a battery-capable one.
Currently I still test cells & work on the cell holders. I am going to 3d-Print them. Will do 4x4 cells, expandible in one direction in order to do 4x8=32cells/ 4x12=48cells etc...
Cells will be spot-welded.
I will use nickel strip on one side and glass fuses on the other. Strips and fuses are spot-welded to the cells and probably soldered to a copper busbar made from twisted copper wire strands, as this seems to be the easiest solution.
On a 1kw inverter with a 14s configuration, the battery will see around 20amps peak with gives me less than 1A per cell. I think this should allow them to last for a bit.
