Well the weather is warming so time to begin working...
I got the reefer box moved onto it's pad. I'm still deciding whether or not to put it on a bunch of concrete blocks (right of the box), or just run a bead of silicon were the box meets the cement. Leaning towards the latter, because it will distribute the weight more directly to the pad. (not sure the structural support in the floor.)
I also checked the voltages on all the modules, which are stacked under compression, but not connected together. After 1 year (really??) they've hardly discharged. I think I charged them each module to 7.8v (~3.9v each side) then parallel connected 7 stacks of 13. I hafta dig through my records, but I think they were at around 3.89v each side after parallel connected for a couple of days. Now they're between 3.872 and 3.860 (I'll post the voltages when I get them in a spreadsheet.
I need to rig up locks for the two doors. The oem ones are way too expensive to replace everything (there's no key codes anywhere--not even on the cylinders. They were also definitely specially keyed on order, as the standard keys don't fit.)
Looking forward to getting my modules in the box, and solar panels on the roof. *** hopefully this spring ***
