Fukuokian
- Oct 15, 2024
- 272
Excellent ideayou take the metal pins and slide them into the existing connectors
As @Korishan says you handle the connectors when assembling the wire -> connectors and in this process I looked at them to ensure they 'looked' the right size - but that's all. I agree with @Korishan that all mine 'sort of snapped in' when assembling them.Did you do any continuity testing between the male and female mc4s when you first made the connections?
I didn't bother with MC4s at my combiner boxes, I just ran the wires directly to the breakers within the box. At the ground array combiner box, used rubber grometts to protect wires as they enter the combiner box. For the roof array, it's conduit from roof to a metal trough to combiner boxes.I had an idea, to avoid an mc4 connection point... I'll probably use 1/2 an empty mc4 plastic housing at the bottom of the combiner box (no metal pin/tube in it). I can feed the wire through it, and tighten the mc4 housing to seal the wire entry. (see pic below)
Thanks for posting the pics!it's conduit from roof to a metal trough to combiner boxes
It's 'metal' conduit w/water-proof connectors, not sure about rigid vs emt. The conduit is affixed to the mounting rails to steady it on the roof end. Going over the gutters avoids roof penetration and doesn't interfere with the gutter.Thanks for posting the pics!(The conduit run is very useful for me, as I need to run mine over the roof edge in a similar way.)
Is that Rigid conduit in the 2nd pic? (not emt right?) It looks very beefy!
That's the standard Midnite 6 breaker combiner box with multi-breaker on/off handle - https://www.solar-electric.com/mndico.html It's really just a box with midnite combiner box with 'group breaker toggle handle' option as apposed to the regular flat metal cover. The red handle moves plastic on the inside that fits over the breaker toggle levers and lets you turn all the breakers on/off at the same time using the red handle.There's no mistaking your shutoff switches... wow, they're big!...I like em!
Are they repurposed from something?
Both are metal, but emt is much thinner (cheaper)...not sure about rigid vs emt
Fantastic work! I have a flat cement tile roof and used the Solar Roof hooks - https://unirac.com/product/solarhooks/ - this one in particularI needed to make custom solar mounting brackets for my Japanese tile roof. You might be able to buy them if your roof allows it, but in my case the rise between my roof decking and the space between the tiles is too small. Here's an example of some of the ones you can buy:
View attachment 33707View attachment 33706
Also, they're expensive (at least here). ($13-16 usd each) I need 20 so I put on my Macgyver hat and bought a bunch of these standard 90deg brackets (bottom of this picture below) and figured out how to bend them without an expensive brake press.
I can turn the bracket around and do the second bend from the opposite side.
Very good work!View attachment 33715
I missed the timing for a smooth control joint and cutting the edges. But, it's good enough for who/what it's for.
(Most of it is covered by the box.)
Now I'm just waiting for the pad to finish curing, then it's time to install the battery box and batteries.
It's only my second cement pour, but I've learned a lot. This time I pre-measured the cement/sand/gravel and water.
Highly recommend doing this, as it saves time and possible mistakes.
Great minds think alike! I tried to go this route too, but couldn't get the minimum rise I need.Very good work!
I buildt the brackets from angle brackets in the hardware store:
Yes, the 'screw angle' tip is good!I used 3 5/8 LedgerLOK screws (thru felt -> truss) and was advised to screw them at an angle toward the truss instead of straight down as it increases the chances of biting into the stud. Used a grinder to cut shallow grooves under the tiles where they overlap so they lay flat over the horizontal part of the roof hook.
Nice info. Thanks @KorishanVirtually instantaneous.
Under heavy loads it is possible to have cells closer to the bus bars deliver more Amps than those further away. But their voltages will be the same.
This is why it's good practice to have Neg and Pos either on opposite ends of the pack or opposite corners to force current to flow through all cells equally
Yep, you could go this route for simplicity; but I'm interested in optimizing my system, especially for battery longevity.Don't overcomplicate it. Just a space heater and a temp controller and you'll be fine. My shed also houses the inverter and mppt controllers so it keeps the temp at above 10C. It's only when the temp outside drops below -10C then my space heater kicks in for short periods of time. My shed is insulated.
Here's the space heater I use, it only draws 200w. Any temp controller works.
I thought about sand batteries and stuff but never followed through. Mostly because I don't have excess solar power during the winters. And building the enclosures to make it safer would be more expensive than buying a space heater.
