chuckp said:
Geek said:You could use them in a USB power bank, if they test OK. Just put a bit of packaging around them. They are the same length as an 18650.
hermitdave said:Geek said:You could use them in a USB power bank, if they test OK. Just put a bit of packaging around them. They are the same length as an 18650.
Yeap. Usual charge discharge voltages. They are a bit sooner and a bit longer and wouldn't fit right.
The capacity mine measured at was around 1000mAh
