I have most of the components (waiting for the panels to arrive)*see Image with the exception of a Victronlow voltage battery disconnect.
1) Does anyone think a Low Voltage battery disconnect would be crucial?
2) My ground is 4ft grounding rod, with 6 AWG copper wireconnecting to the Negative Bus.. Is this the suitable position?
I do use a 12v converter for lights, which will have a parasitic draw and consider this to be non issue.
The purpose of this setup was to run lights andcharge tools in a small workshop, with a emphasis on making future upgrading as safe/easy as possible, adding additional solar panels, larger AC inverter, and increasing the capacity of the lipo battery bank. Eventually runa small window AC unit to the shed. I'm building custom batteries from 18650's salvaged from modem battery packs.
Any recommendations?
Thanks
-Tony
Thanks
-Tony
