Update Gossip: Cleanup continues (sigh!) + new panels ordered
Got the PV array dismantled. Next up is to remove the metal shed roof and then tackle the awful water tank mess. Have the mess go from higher (PV and Shed Roof) to lower (Water Tanks). Glass and panel 'bits' are everywhere. Frankly, its getting to me a bit to have to dismantle / cleanup rather than build... but its coming, bit by bit.
Beware neighbors - I asked the neighbor if he'd think about lowering or offset from fence his pool gazebo (in pic above) as it shades the bottom row of panels in winter and he let loose about my panels being a 'industrial complex eye sore' and could I please move them!. As a reminder, here's what they look like from his deck and he can't even see them from his yard.... because I kept the tilt only 17deg to lesson the impact.
Sigh! Not sure if it's actually about panels or being annoyed due to fire or just unfriendly (or all 3).
After a fair amount of consideration, I ordered 26 x 345w panels from -
https://www.ebay.com/str/surplussolarproducts I'm guessing these are 'middle of the road' but they say 25yr warranty.
These are 'new' and includes shipping so it's $3200 / 26 = $123 per panel.
The *FIRE* has me re-thinking things. I was over-paneled into 3 x Midnite 150s because over 1/2 the year it never reaches the max but at least 3 months of the year they max and the wiring can hit / stay at 55C / 131F for several hours a day.
In my new design, I'm going to lighten the amps and go with 4 x Midnites and
shoot for 35C max wiring temps with the idea of lessoning fire risk.
It's interesting but I can't easily fit just any panel size to either the array or the existing system. My array is 33.3ft long = 12x horizontal in old panels but only 11x in 345w panels. Also it's build around 10ft Unistrut cross members with ~8inch cantilever. The 345w's are 68.8in so 2 vertical is 137.85in - 120 (10ft) = 18inches / 2 = 9 inch cantilever on each end. The 400w, 500w, 550w panels create a 20inch+ cantilever on each end which is more than seems prudent.
Also, these 345w's are not crazy out of line Voc wise with the 57 x 285w panels I already have - so I could parallel them in a pinch and get reasonable results.
All in all, the array and existing charge controller system and panel availability add quite a few constraints to choices when it get's right down to it.
My old setup was 14.5kw and this will get me to 15.1kw - a bit of a boost.
