OffGridInTheCity Build
Happy to hear and happy new year! 😊 Are they still holding voltage?
Thank you and happy new year to you/all as well! :)
Yes, the fixed packs are still steady. I made this a big deal / put it off (in my head) but the find/fix was straightforward and pretty low effort (really).
Updated Jan 2026....
Living off-grid can bring to mind moving to the country... but the 'country' has it challenges so why not transform my city home to be off-grid capable? Water via rain-harvest (20,000g/year), Solar power to run a 100% electrified home (15,000kwh/year). Wood based heat (unfortunately) is not an easy option - and winter months are not enough power - not sure how to overcome this yet.
The Solar power design goal is to consume all that is produced. Its an ongoing, off-grid, power production focus. I'll use later posts to show details/pics. If there's additional metrics you're interested in, let me know and I can add here or share.
Power / Water / Maintenance:
Powerwall Cycles:
Powerwall Detail - 52v@260ah = 13.5kwh per battery x 8 batteries = 108kwh Powerwall
2026 Goals
* Wood based heat - boiler or forced-air or even fireplace (as city allows). During winter months (Nov, Dec, Jan, Feb) there isn't anywhere near enough PV for the heat-pump to keep things warm.
* More powerwall
My own very small project, pv and 16s battery, zero export to grid continues with lessons learned.
My initial design for limiting the inrush current to the battery GTI involved placing a 22R NTC in series with the high (+) side to the GTI, after battery power on, this limited the inrush current to about 2.5A and after a delay of about 3 sec an SSR would short out the NTC however, with SSR on and generating it had about 1v across it, the lesson learned is that the a full battery under discharge is about 52v so 1v drop causes the battery GTI to sense an apparent SOC, a big loss of charge, meaning it cuts out early on its lower limit.
The design work around is to use a current sensing relay (Geya GRI8-01) that shorts out the NTC after a delay once the GTI starts generating. This arrangement is fail-safe in that if the NTC fails open circuit the GTI cannot start generating, preventing inrush damage to the GTI dc input components. Again, the lesson learned is that the dc supply to the GTI must come straight from the battery ideally without any interposing resistance. The GTI design would be better served by having separate voltage sensing wires to eliminate even very small resistance in connecting cables carrying high dc amps. :)
Update: Work on battery #11 thru the winter coming along... nearing 1/2 way mark.
These Battery Clearing House cells are fantastic. Doing diligence with a capacity test and a 3 week self-discharge test - but every single cell is 3.5v out of the modem packs, OPUS reporting 2650-2750mah in capacity tests (spec is 2600mah), and have been 100% pass for self-discharge.
Looking forward to a good, 11th edition to the powerwall. And I have enough cells for battery #12.
Fantastic work!
It's amazing you've done #11 battery packs. 😊
Where did you get these battery clearing house cells and what was the price?
Update: Battery #11 hooked up! Parallel'ed onto the powerwall 'live' - getting quite cavelier these days :)
Up to 154 longmons / 148.7kwh on paper. *At 2,570 cycles, overall capacity has deteriorated 10-15% I'm guesstimating - so 148.7 * 85% = 129kwh current capacity.
Not sure what happened with 3 errant pack voltages - spiking blue bars to the right. I use an iCharger X8 to pull down the finished packs to a "Storage" voltage of 3.7'ish but apparently it didn't pull packs #144, #148, and #153 all the way down. I didn't double-check - getting 'sloppy' a bit these days.
#141 - #154 are the used longmons I bought earlier this year and at first I thought they were mis-calibrated? but a voltmeter shows them to be accurate. And the Batrium Sync went flawlessly, so they seem to be working. In any case, auto-level and individual pack discharging (using hobby charger) will take care of this reasonable soon.
Battery #11 located on top of another one. Used 8 (8" x 8") plastic dividers spaced between the bottom row of packs to help support a shelf above them for this battery. A bit of a house of cards but should let me pull out individual packs on the bottom row if I need to work on them. Planning to repeat this for battery #12 (on top of #11).
Nice work Offgridinthecity! 😊
Almost 130kwh current capacity! 😃
Did you ensure the connection of pack #144, #148, and #153 was properly secured?
Thank you!
Yea... the lugs + copper plate connectors are bolted with 'ken torque' :) - e.g. as much torque as I can put on the wrench!. It's just a bit of sloppiness following my process. Got the 1st pack back inline and working on the remaining 2 packs...
What's (always been) interesting to me is the 'max difference variance' that occurs over the charge/discharge voltage range among the packs.
Right now (time of this post), near the 'bottom' battery voltage for last night's cycle, the max difference between packs is minimal - 80mv - but as this charges up today, the 2 'errant packs' will rise faster than the others and the difference will be 170mv till I bring these inline.
Heat / time of year (angles) has a dramatic affect on max PV kw
We've entered our 100F/38C+ season and home power consumption has jumped dramatically from spring/fall's 50kwh/day consumption to summer's 70+kwh/day consumption due to home cooling. The 15kw PV array is adequate to keep up with 70+kwh demands but the heat dramatically changes the max PV output.
In cooler parts of the year, it's common for me to see 12kw PV with 15kw spikes on the 15kw array but the HOT time of year causes the PV to top out at the 8kw range instead of the 12kw range. This is the longest daylight part of the year for me so the extra hours are enough to enable 90kwh+/day PV as needed but at a lower peak PV.
Interesting (to me) how spring/fall/COOL is more "15kw array = 15kw peaks" but summer/HOT is more 7kw, 8kw peaks thru the day.
  • Like
Reactions: kje
True, I was surprised, too, how on nice summer hot days -> 2x 280W (nominal 560Kwp) panels reach around 470/480W, while on a slighly cloudy, cooler day they reach a peak of 575W! More than the nominal power... fascinating LOL
There's videos on YT of people cooling down their panels during the summer time, using water sprinklers, to get higher output.
And that's also why you make sure to not get right at the voltage limit for the controller. When the sun first comes up, the panels can go over their rated voltage as well. Capacitors don't care much about "amps" in this instance, that voltage goes too high and shorts them out. Same for some of the FETs or other components.
I've actually been thinking about having a circuit that would keep the voltage clamped on the string until the MPPT can kick in. This would allow me to have 4s instead of 3s on the smaller controller. It never goes over 110V and mostly stays around 85-90V. Adding a 4th panel would keep it below the 140V max. It's just that the open voltage can spike close to 200V, and that means 💥
I need some additional Greenworks 4.0ah @ 40v batteries. I was annoyed going into this because $120 for a 4.0ah battery is highway robbery and I did find $80 here and there but... there was a catch. Either hidden $40 shipping! (shame on you Lowes!) or not genuine Greenworks so who knows (ebay/amazon).
I found GreenWorks 40v @ 4.0ah for $80 (instead of $120) on one of the many listings on Amazon and purchased but... they switched out the link to 2.0ah and the original link is gone and shipped them to me. This really frosts me 😵‍💫
I'm not very good at 'fine battery work' but I'm really annoyed so I took one apart and it's not complicated - e.g. it has 10 x INR 18650 20p cells for 2.0ah instead of 20 cells for 4.0ah. You can see the empty spots and to my annoyed brain it looks like I can tear open the nickel strips, slide in the missing cells, flatten out the torn up nickel, and use some solder to re-connect.
These are 30a continuous cells but found some (new) ICR18650 20P ones at Battery Clearing House for 1.50 each and clicked buy...
Stay tuned....
I'm not very good at 'fine battery work' but I'm really annoyed so I took one apart and it's not complicated - e.g. it has 10 x ICR18650 20p cells for 2.0ah instead of 20 cells for 4.0ah. You can see the empty spots and to my annoyed brain it looks like I can tear open the nickel strips, slide in the missing cells, flatten out the torn up nickel, and use some solder to re-connect.
Might be able to. I was gonna suggest 20Q or 30Q cells, but those are actually lower sustained current, 15A vs the 30A these pack cells can do. However, you could still upgrade the packs perhaps, with better capacity cells
Are you cannibalizing old packs to make higher capacity ones?? If so, you don't want to mix old cells with new ones. There will be a capacity difference. But if you take a new(er) 2Ah pack and sacrifice it to use those cells in a bigger pack, that'd probably be just fine.
It's a 'new' Greenworks Battery - I'm going to try adding EVE ICR18650 20P cells (30a) in parallel with existing INR 18650 20p (30a) - both are 2000mah capacity.
You could try... this The Internet Archive: Paste the old URL or ASIN into the Wayback Machine to view snapshots of what the listing looked like in the past.
It was a listing page with multiple options. I picked the 4.0ah option and did the one-click check-out but didn't follow up with a detailed inspection of order in my order list... and received 2.0ah the next day. Likely my fault (could have cancelled from order list once purchase completed) but I still feel bait-switched - annoyed!
It happened this morning, showing the high voltage spike right when the sun is coming up
My controller can only handle a max of 500V. It's still pretty warm out (we've actually been under a heat advisory past few days). Not sure what's going on with the voltage on the 2nd array, it might be picking up the flood light from my neighbors.
These are in 13s configuration with about 36VoC, which puts me at a max VoC of 468V. I have a little bit of leeway, but not a whole lot. If I were in colder climate, I definitely would not be at 13s.
